When I try to install some softwares I get the following message from
16 bit windows subsystem
C:\windows|\system32\autoexec.nt. The system file is not suitable for running MS-dosand microsoft windows applications.
I can't install some programs due to this.
Please help me to find a solution
I guess u cannot have a path specified ? C:\windows|\ ?
howz this possible ? Please provide us with a exact location.
And post such threads only @ QnA Section !
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
Why do I keep getting this error message C:\WINDOWS\System32\Autoexec.nt?
You will receive an error message that reads something like this:
16-bit MS-DOS Subsystem
path to the program that you are trying to start or install
C:\Windows\System32\Autoexec.nt The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose 'Close' to terminate the application.
Solution?
The easiest is simply inserting the Windows XP CD into the CD drive and clicking start --> Run and entering:
Microsoft has provided a solution for this problem here. It is related to running DOS based or 16 bit applications in Windows XP. If you either do not have this CD for some reason try downloading it here. After downloading the .zip you will have to extract it to your windows\system32 directory. If this file does not work properly for you please check the feedback thread for assistance on your specific version of windows.
Let me tell u this
first search in the forum
any way here it goes
u have installed ur windows on NTFS partion so it is Autoexe.nt
but ur program require autoexec.bat which is created when u install window on FAT32
i guess here is the prob
Music is like Sex, The more you get, the more you want.
