Old 05-12-2004, 07:55 PM   #1 (permalink)
Default Help Knoppix Hard disk Install
hi guys
i installed knoppix 3.4 on my hard disk
it has loaded lilo as the boot loader,
now when i go to knoppix i see all the initial steps then the screen goes black with out of frquency message,even ctrl + alt + f1 gets me the same screen
i know that the error is due to the wrong config of xf86 - which was not asked for during installation , but please get me out of it
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 06-12-2004, 12:21 AM   #2 (permalink)
i am even not able to write to my linux partition from knoppix cd, i am able to write to a fat32 partition
Old 07-12-2004, 06:52 PM   #3 (permalink)
FooBar Guy
GNUrag's Avatar
Reconfigure your XF86config by any of one the two methods.
1) # xf86config
this menu driven script will rewrite your x config file with a new one that you choose. This is the best option, and i have saved many people's lives with this...
2) # dpkg-reconfigure xserver-xfree86
Reconfigure your debian packages that belong to xserver
Use this to mount your ext3 partitions.
$ su
# mount -t ext3 -o rw /dev/hda6 /mnt/hda6
Or better you can make changes in /etc/fstab and make the entries in 4th column from ro to rw
http://web.gnuer.org
GNUrag is offline
Old 07-12-2004, 07:09 PM   #4 (permalink)
thanks for the reply but i have already solved both the problems, so moderators can lock this thread
i used the super user mode in Knoppix cd to gain access to the already mounted as rw reiser partition. there i changed the frequency range in the xf86config-4 file and then my knoppix was booting properly
- by gohan89
