Old 13-08-2006, 04:05 PM   #1 (permalink)
Default PC restart
MY pc keeps restarting about every hour or so ..
it gives me that big blue screen error.
then it :
1. Either hangs on the blue screen error
2. OR hangs on the a8NE screen
3. OR gives a boot error [which it also gives when i restart.i always have to manually select my bootdisk. editing the bios boot prority and hdd boot priority does not help. it reverts every time. i have 1 OS. XP Prof SP2]
4.Monitor light turns orange and nothing happens. I have to take out 1 piece of RAM and put it back and then it wrks .....
HELP!!!
AMD Athlon 3500+ 939
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
Old 13-08-2006, 05:51 PM   #2 (permalink)
Tux Fan
shaunak's Avatar
Default Re: PC restart
try cleaning your ram contacts with an eraser.
also calculate power usage and see if smps is good enough.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 13-08-2006, 09:06 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
Do as shaunak told u..also it may be heating problem..chk ur Processor fan is working or not..or chk for any clutters in the cabinet ...also u can get Mother Board Monitor for Day to day use....Get info/download here : http://www.majorgeeks.com/download.php?det=311
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 13-08-2006, 09:27 PM   #4 (permalink)
samrulez's Avatar
Yep......seems to be memory prob......
Remove the memory modules and see is the connectors r clean and not black...also clean them with help of some Sand Paper.....but be carefull...
Sam :D Rulez :lol:
samrulez is offline
Old 14-08-2006, 12:56 AM   #5 (permalink)
flashget also keeps corrupting my downloads .. as in the above file , motherboard montitor .. the setup runs , but some files dont .. i did that like 5 times ..
proccy fan is wrking nicely .. i have a 500W SMPS .. i jsut got a full cabinet cleaning done (yes .. from inside .. im not that stupid .. ) amd theres not a speck of dust ..
and y shd i keep givin a boot error then ?
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 14-08-2006, 08:24 AM   #6 (permalink)
Let the music play.....
djmykey's Avatar
RAM problems. If u have any frens who have almost same config or ur sure that the ram chips match u can bring his ram put it in ur machine and check it out. These r pure symptoms of a RAM freq mismatch.
djmykey is offline
Old 14-08-2006, 08:36 AM   #7 (permalink)
but then , if i put them one at a time then it shd wrk .. but it doesnt ..
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 14-08-2006, 12:15 PM   #8 (permalink)
djmykey's Avatar
Both the RAMs might b mismatch. Did u buy them at the same time or diff. If diff then it might not be a RAM problem. Dunno man this might b difficult to tell online.
djmykey is offline
Old 14-08-2006, 05:20 PM   #9 (permalink)
same time . both r 1GB transcend ..
i also noticed that generally it doesnt give an error on windows startup , but after every few days , it gives like 20-30 minidmp errors ..
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 14-08-2006, 06:57 PM   #10 (permalink)
djmykey's Avatar
This is the answer I was looking for not how much they were or what manufacturer.
And by this I meant the RAM and the mobo not the RAM's
djmykey is offline
Old 14-08-2006, 07:47 PM   #11 (permalink)
my sig says my whole rig .. A8NE ..
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 15-08-2006, 07:51 PM   #12 (permalink)
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 16-08-2006, 04:10 AM   #13 (permalink)
Ishan's Avatar
sorry not read all the above posts...but might not be it a CMOS cell problem coz his boot priority is changed everytime.? just think of it.
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 16-08-2006, 08:03 PM   #14 (permalink)
guys .. what abt wat ishan says ???
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 19-08-2006, 11:16 AM   #15 (permalink)
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 20-08-2006, 12:32 AM   #16 (permalink)
Ishan's Avatar
Arey...Plz reply na...I am tealking to u members...just guess! might it work!
Ishan is offline
Old 20-08-2006, 08:04 AM   #17 (permalink)
djmykey's Avatar
Arrey if its a BIOS battery problem the PC wont boot itself. But yaar there is no harm in trying it out na, the battery costs hardly 15 buxx so go ahead with it.
djmykey is offline
Old 20-08-2006, 05:04 PM   #18 (permalink)
i dont think its a battery prob . i think my mobo [which just came bac from replacement] has a prob coz its not detecting my frnds USB drive also
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 04-10-2006, 01:56 PM   #19 (permalink)
its fixed .. my AGP was the prob .. i reaplaced that and its working fine now ...
fr now i have a 6100 instead of my x800xl !!
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
- by gohan89
