Old 13-08-2006, 01:03 PM   #1 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default How to send Fax?
I use MTNL wireless connection phone for internet. The problem is that it (Huawei modem) doesn't shows up as a fax device. Can anyone tell me how to send (and maybe recieve) faxes on my pc?
hemant_mathur is offline
Old 14-08-2006, 08:22 PM   #2 (permalink)
Default Re: How to send Fax?
Hey guys plz reply .. any free software or net service ?
Old 14-08-2006, 10:11 PM   #3 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
check that ur phone supports fax services.....for the software.....try supervoice
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 15-08-2006, 11:14 AM   #4 (permalink)
It says it does but am unable to send fax through it. Tried supervoice and Bitware but they are unable to send fax .. any free online service??
Old 15-08-2006, 09:01 PM   #5 (permalink)
through Huawei modem you cannt send fax
dinesh1 is offline
Old 15-08-2006, 10:57 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yep, you need a Fax modem and a dial up line.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-08-2006, 11:33 PM   #7 (permalink)
vandit's Avatar
www.trustfax.com/
www.emailaddresses.com/email_2fax.htm
www.instantssl.com/ssl-certificate-products/fax-free.html
www.comodogroup.com/products/fax/index.html
want ne other????
vandit is offline
Old 16-08-2006, 09:49 AM   #8 (permalink)
Thank you all for the reply .. query solved.
- by gohan89
