Old 13-08-2006, 12:32 PM   #1 (permalink)
Default Special Characters in ur filename!
Have u ever seen the icon name of NFS Most Wanted on the desktop, when its installed properly. You might have notices the 'TM' character after the text 'Need For Speed'.
Does n e 1 kno how to custom put such characters in your filename?
Life is a lesson, you learn it when you\'re through!
detj2004 is offline
Old 13-08-2006, 01:11 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Special Characters in ur filename!
This link will help you.
http://home.earthlink.net/~awinkelri...shortcuts.html
http://twitter.com/blueshift155
blueshift is offline
Old 13-08-2006, 01:40 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
their are alt + 0149 for • & many other alt code just press alt & than type code that character will come
ya if you dont know the alt code see it from the work you can also do it either way just type file name in word copy it from word & than paste it as your file name
Very Simple......
satyamy is offline
Old 13-08-2006, 02:19 PM   #4 (permalink)
GeekyBoy's Avatar
Hey guys
Found out that Alt + 255 enables a file to have no filename!!
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 13-08-2006, 03:03 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: Special Characters in ur filename!
Originally Posted by GeekyBoy
Hey guys
actually it gives a space & nothing else
dont need to type code just press spacebar
satyamy is offline
Old 13-08-2006, 04:14 PM   #6 (permalink)
Tux Fan
shaunak's Avatar
Look throuh start>all programs>accesories>system tools> charecter map and scroll
Google "ASCII map" to get full list.
eg:
>> 97-122 :-small a to z
>> 65-90 :-A to Z
>> 1~9 :-☺☻♥♦♣♠•◘○
>> ™ :-153
and there are also 65k+ unicode chars
¨°o.O-(×÷·.·´¯`·)»<º))))><.·´¯`·.[Shaunak]¸.·´¯`·.¸><((((º>«(·´¯`·.·÷×)-O.o°¨
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 13-08-2006, 08:14 PM   #7 (permalink)
dOm1naTOr's Avatar
@ thnx guy.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 13-08-2006, 09:41 PM   #8 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
friends i tried it in my pc and it works fine.. but when i tried the same way in my laptop it is not working.. why is it..
i use in pc xp with sp2 but sp2 was not integrated but was putted after while my laptop has xp integrated sp2 installed.. is it the reason or somethin else??
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 18-08-2006, 03:44 PM   #9 (permalink)
GeekyBoy's Avatar
Cool Re: Special Characters in ur filename!
Hey
Just pressing spacebar won't work.It will just revert back to the previous filename.Press ALT+255 to have a file without a filename.
GeekyBoy is offline
Old 18-08-2006, 07:31 PM   #10 (permalink)
Tux Fan
shaunak's Avatar
ASCII chars are constant on all systems excepting some non standard charecters like alt+1[☺] etc.
On systems not capeble of displaying this it will apear as a rectangle. [ࡡ]
charecters like Alt+032 onwards should shou up fine if all fonts are correctly installed.
Cheers
Shaunak
shaunak is offline
Old 18-08-2006, 09:27 PM   #11 (permalink)
Alive Again...
satyamy's Avatar
Hey
ya thats right......
satyamy is offline
Old 18-08-2006, 10:02 PM   #12 (permalink)
eWebGuru
ahref's Avatar
ascii code of spacebar is 32, not 255. alt 255 give different character which is also invisible (space)
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 18-08-2006, 10:26 PM   #13 (permalink)
Ishan's Avatar
Ok..if this is solved ...
another ques...what does that"TM" and many other things like something written on Windows Xp Prpfessional and on some film production names and all that mean..Are they some shortcuts or what?
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 18-08-2006, 10:28 PM   #14 (permalink)
Commander in Chief
QwertyManiac's Avatar
Lol...
TM - Trade Mark
(c) - Copyright
(r) - Registered
If that's what you were asking about.
Harsh J
www.harshj.com
QwertyManiac is offline
- by gohan89
