Old 05-12-2004, 04:32 PM   #1 (permalink)
Default I CAN'T EVEN UNDERSTAND THE PROBLEM...
When i click the start menu in my PC,i am being showed a waring saying some items cannot be shown try reducing the size of the icons...!!
Plzzzz....Could any one solve this for me....
Thanxxxxx
Regards.
U CAN\'T STOP WIZARDS
wizard_with_a_wand is offline
Old 05-12-2004, 05:17 PM   #2 (permalink)
- right click taskbar>properties , choose show small icons in start menu
- else restart in safe mode , does it happen ? if yes reboot and it might fix it .
- if above dont work , just give more details on OS and stuff
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 05-12-2004, 05:20 PM   #3 (permalink)
If you are using Windows XP, right click on the task bar
Properties > Start Menu > Customize
Under "Select an Icon size for programs" select "small icons"
If you are using Windows 98, right click on the task bar > Properties
and check "show small icons start menu"
Whatever happens, happens for good!
ramank is offline
Old 05-12-2004, 10:36 PM   #4 (permalink)
ur screen resolution is too small for all ur icons to be displayed
increase screen resolution ... ur error will be gone
ofcourse that is if selectin "small icons" doesnt help ...
anyways its a good idea to have a higher res.
this error is usually seen when the screen res. is likr 640*480 .. sometimes even on 800*600 ...
No Mercy, No Limits.
theraven is offline
Old 05-12-2004, 11:21 PM   #5 (permalink)
Posts: n/a
just make icon small dude
Old 06-12-2004, 01:04 AM   #6 (permalink)
Default THANXXXXXXXXXX
THNXXXXX EVERYONE
It's Working ...But the icons got sooooo small how can i detect bcz of which items the message is displayed so that i can delete them...
Thnxxx again
Regards
Old 06-12-2004, 05:07 AM   #7 (permalink)
hey dude !
I dont think ur Wizard by anyway....
Seems tht ur prbs are fixed !!
Great !
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
go4inet is offline
- by gohan89
