Old 13-08-2006, 06:24 AM   #1 (permalink)
eagle_y2j's Avatar
Arrow Webpage's Layout
Can some1 plz guide me how to contol my webpage layouts So that page works fine in all resolutions of screen and different browsers.
I created some pages for my site using table to contol layout but thoes pages work only work fine @1024*768 and in 800*600 layout looks grabbled! Wat to do?
PS:-Tips and tricks to control layout are also welcomed
Registered LINUX USER #438929
eagle_y2j is offline
Old 14-08-2006, 01:37 PM   #2 (permalink)
tuxfan's Avatar
Default Re: Webpage's Layout
Whats the URL of your site? Lets have a look at it frst. Usually, you should optimise your page for 800x600. So max width should be 778 or something like that so that there is no horizontal scroll bar. Vertical scroll bars are ok.
Secondly, using tables is an old unoptimised way of laying pages. Use CSS, DIV, etc. to layout pages. Have a look at following links. For more, use Google
https://www.decloak.com/Dev/CSSTable...Tables_01.aspx
http://www.sitepoint.com/article/tables-vs-css
http://www.dmag.org.uk/resources/des...sforlayout.asp
tuxfan is offline
Old 15-08-2006, 11:41 AM   #3 (permalink)
eagle_y2j's Avatar
till now I haven't uploaded it coz it is full of bugs so no URL till now .I ll try ur links any 1 else plz post some tips?
Old 15-08-2006, 11:54 AM   #4 (permalink)
WHYIWASBANNEDFORNOREASON's Avatar
While giving dimensions use % instead of pixel
WHYIWASBANNEDFORNOREASON is offline
Old 15-08-2006, 12:12 PM   #5 (permalink)
tuxfan's Avatar
% and absolute values have their own pros and cons. So it may suit, may not suit your design.
Unless and until you post your code, it may not be possible to troubleshoot it So show it somehow How can anyone suggest you improvements without looking at your original work?
tuxfan is offline
- by gohan89
