Old 12-08-2006, 05:59 PM   #1 (permalink)
Default System Administrator
My office computer is on a LAN with Windows 98 .Whan I try to open network panel in 'Control panel' it says your System Administrator has disabled the network panel.How it is being done and how can I access the network panel? Thanks.
Windows 7 Ultimate,Intel Core 2 Duo E 7300,3 GB Ram,ATI Radeon HD 4850 graphics card.
pramod_kk is offline
Old 11-09-2006, 04:52 PM   #2 (permalink)
Default Re: System Administrator
You can't access the control panel until n unless your administrator wouldn't let it happen. your sys is behaving as a host.. n you are not suppose to deal with the administrative rights.. so sorry bad luck buddy
speedrider - The ultimate
speedrider_100 is offline
Old 11-09-2006, 09:00 PM   #3 (permalink)
vikasg03's Avatar
no you can remove this messge by edit the registry. just check in run prompt whether regedit works or not?. if it open then i will give you one .reg file and this limitation is removed.
Vikas
vikasg03 is offline
- by gohan89
