i have a p3 866MHz pc with 2x128=256MB RAM
Plz suggest me will there be any difference in speed if make my ram to 512 MB..\
also telll me will the motherboard support that much ram..
i think motherboard is 810 via chipset.
Does anybody wanna sell one 512 SDRAm or two 256 MB SDram pieces..??
So suggest me guys should i upgrade to 512MB
But as windows vista wants minimum 800MHz processor with512MB ram..
SO i lack only in Ram..
also tell me if vista can be supported with greater ram on same 866MHz p3 pc then speed should be increaded for other applications.
wwhat do u say guys
