View Poll Results: Which desktop shall I buy?
Assembled 25 96.15%
Branded 1 3.85%
Voters: 26. You may not vote on this poll
Old 11-08-2006, 05:41 PM   #1 (permalink)
Question Branded or Assembled?
If I buy a new computer which should I opt - Branded or Assembled? Are Branded computers cheaper? If so, how they are providing it cheap?
kisorgovinda is offline
Old 11-08-2006, 05:43 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Branded or Assembled?
Branded ones have a support advantage apart from OEM software in it. I'd go for an assembled one since I've learnt to take care of my system by now. ANd an assembled one is generally much cheaper and better in performance than a branded one.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-08-2006, 11:35 AM   #3 (permalink)
tuxfan's Avatar
If its a desktop, assembled for sure! You can customise it to your needs/budget, its cheaper, maintenance is easier if you do things on your own like some of us
tuxfan is offline
Old 12-08-2006, 01:57 PM   #4 (permalink)
shashank4u's Avatar
assemble it ,
u will learn something about computer parts .
but triple check about the prices and model no . of
parts u wanted as there is a lot of hera pheri.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 12-08-2006, 02:07 PM   #5 (permalink)
UBERGEEK
PCWORM's Avatar
If know little basics about computers and its components such as a processor
motherboard, etc or even if you read every page of DIGIT, then you should
go for an assembled pc....
and yes, assembled PC's are cheaper...
PCWORM is offline
Old 12-08-2006, 03:26 PM   #6 (permalink)
drsethi's Avatar
assembled because
you can get custom parts like CRT/LCD monitor Intel/AMD Amount of Ram 512/1GB
Branded generally are poor in RAM/Monitor/Motherboard
Option of OS
drsethi is offline
Old 12-08-2006, 04:12 PM   #7 (permalink)
Google Bot
Pathik's Avatar
ASSEMBLED neday........
Pathik is offline
Old 12-08-2006, 05:57 PM   #8 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
One more vote for Assembled!
In assembled PC, u can get the things u want.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 12-08-2006, 06:07 PM   #9 (permalink)
Wink Re: Branded or Assembled?
well yes. assembled anyday. if you know your city(like SP road in bangalore), you can even assemble a pc yourself at a fraction of the cost of the branded one. but better be well informed before you make your choice of components because incompatibility is a big problem
prashanthnbhat is offline
Old 12-08-2006, 07:25 PM   #10 (permalink)
tuxfan's Avatar
Poll added
tuxfan is offline
Old 12-08-2006, 07:29 PM   #11 (permalink)
I see right through you.
Sykora's Avatar
I'm for assembling as well. It's a great learning experience each time.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 12-08-2006, 08:11 PM   #12 (permalink)
In Shamful Mystery
led_shankar's Avatar
Yaar, Can someone who has assembled before tell me whether you physically set up the stuff yourself, and if that is difficult/dangerous?
led_shankar is offline
Old 12-08-2006, 09:07 PM   #13 (permalink)
Sykora's Avatar
I set my own Computer up ie bought the parts and put it together. If you're stupid, it is dangerous. Not if you RTFM
-- Sykora --
Sykora is offline
Old 12-08-2006, 09:14 PM   #14 (permalink)
Alive Again...
satyamy's Avatar
I like Assembled....
satyamy is offline
Old 12-08-2006, 11:45 PM   #15 (permalink)
Question Re: Branded or Assembled?
Shall I have to get any hardware training to assemble a computer of my own? Or, wherefrom I would know how to assemble it?
Old 12-08-2006, 11:51 PM   #16 (permalink)
Microsoft MVP
These links will help U:
http://www.learnthat.com/courses/computer/buildpc/
http://www.mysuperpc.com/pc_assembly...ter_case.shtml
http://www.clicksbucks.com/howtobuildpc.html
http://www.his.se/templates/vanligwe....aspx?id=17711
Old 12-08-2006, 11:56 PM   #17 (permalink)
shashank4u's Avatar
computer assembling is so easy go on googling for tutorials with pictures.
they are so easy that nothing fits wrong,
the sockets in computer parts are one way only u cant fit them in
wrong way.only thing to learn is jumper setting of harddisk and dvdrom.
Old 13-08-2006, 12:56 AM   #18 (permalink)
18 Till I Die............
Assembled will be the way to go, if you know about computers and what to buy otherwise there are chances of getting wrong config. That's what happened to me. I got some unneeded accessories. And those which I needed were underpowered.
http://www.bash.org/?258908
mehulved is offline
Old 13-08-2006, 05:52 AM   #19 (permalink)
eagle_y2j's Avatar
Assembeled bole to puri Aazadi!
Registered LINUX USER #438929
eagle_y2j is offline
Old 13-08-2006, 07:50 AM   #20 (permalink)
Commander in Chief
Teeehehe and if something goes wrong, try this.
http://tinyurl.com/hdvmg
Harsh J
www.harshj.com
Old 13-08-2006, 08:06 AM   #21 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
kisorgovinda, go for assembeled pc any day. you will learn sth abt h/w as well. if u need help ask some of ur geek frnds or post a req. for help here
If you want to be happy, be.
shivkumar is offline
Old 13-08-2006, 10:19 PM   #22 (permalink)
@Vishal Gupta Thank u for those useful links.
@QwertyManiac Thank u for ur useless link hehe
Old 13-08-2006, 11:04 PM   #23 (permalink)
a_g = JPKN
s18000rpm's Avatar
If you are new to PC's , know nothing/less about H/W, etc... then go for a branded PC like HP, Dell...
Coz buying a branded PC has a lot of advantage,first the QUALITY, & if you have any problems with your PC H/W or S/W (O.S), the Manufacturer (e.g. HP) will sort it out for you.
The only disadvantage is that you pay a lot for what you get, but again you get a lifetime service support(charged after warranty).
Otherwise Go for the Assembled one.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 13-08-2006, 11:13 PM   #24 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
well if u want the best deal and bang for your buck , assemble one mate .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 13-08-2006, 11:52 PM   #25 (permalink)
Alive Again...
satyamy's Avatar
Do anyone suggest which Branded PC should i buy
& what is the lowest cost of PC in Branded (no matter wht the config is)
satyamy is offline
Old 14-08-2006, 12:36 AM   #26 (permalink)
a_g = JPKN
s18000rpm's Avatar
HP is the best bet when going for Branded PC's.
It may be costlier than other branded PC's, but HP has its Advantage, its Vast Service Back-Up.
To get the best deal, you'll have to check the Different OFFERS/Packages the dealer will give you. For this check out various HP outlets.
it's b'coz some dealers give less/no package.
i got my HP from local dealer who gave the following package-- HP Pavilion+ HP All in One Printer+ LogiTech WebCam+ UPS+ HP Speakers & Sub Woofer. I got this last year for 40K.
Go here & check prices for the model you are interested in http://h50188.www5.hp.com/store/default.asp?
& on the left side select "PRODUCTS" & under "Desktops" select "Consumer's PC", & then if you want a PC based on XP Home edition go for "a-series", for Media Centre PC's select "m-series" & cheapest HP PC's go for "Compaq Presario"
Old 21-10-2006, 02:55 AM   #27 (permalink)
hailgautam's Avatar
Desktops are best on assembling, they are cheaper and alos much more flexible. Well as for laptops we do not have much choice in India.... do we?
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 21-10-2006, 12:27 PM   #28 (permalink)
ashisharya's Avatar
assembled will b cheaper
branded provides u warranty and all time support...
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
- by gohan89
