hello everyone,
i have earlier opened CLIPBOARD by typing "clipbrd" in Run command.. but now it is not opening. it says 'Windowa cant find clipbrd'.. can u tell me wats the problem?
^^ you have NOT deleted it. Infact you just uninstalled the 'clipboard viewer' from 'additional windows components'.
To get back your "clipbrd" goto RUN and type appwiz.cpl now head up to Add/remove Windows components. There go into the details of Accessories and click the check box near the Clipboard viewer. Press OK until your PC is fed up with you.
