Old 10-08-2006, 05:09 PM   #1 (permalink)
Default Increase Sound Quality
Hi,
I've some Audio Books in mp3 format, some of them is not in good condition, ie low bitrate, poor volume etc,
How can I Increase the volume and sound quality of the said audio files?
which software (Best) should I use?
How do the bitrate and frequency affect the audio files?
Which audio format is good?
In order to search this topic in this forum, what are the keywords should I use or if you are the person, how will you search?
I'm asking this question coz several times I couldn't find the correct results, and there will be a lot of results that I don't want.
thnx
Raaza is offline
Old 10-08-2006, 08:11 PM   #2 (permalink)
q3_abhi's Avatar
Default Re: Increase Sound Quality
U can use software like Sound forge to edit ur mp3 files
Remember that converting from lower bitrate to higher wont increase the sound quality, u can increase the volume but not the quality.
Higher the bitrate , better is the sound quality. U can clearly notice the difference when u hear the same song in different bitrates.
You can use any format. Wav is the best coz its raw , uncompressed format.
Many others are available n sound quality will depend upon the bitrate at which the song is compressed. U loose frequencies on compression.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 10-08-2006, 08:51 PM   #3 (permalink)
isn't virtualDub for video editing?
I tried with version 1.6.15 but there's nothing on audio editing.
I found in CD_DA Extractor, an audio converting software that ther's 3 wav formats ie .wav (fraunhofer mp3 codec), .wav(standard), .wav(ADPCM)
and I confused, which one is best?
Raaza is offline
Old 10-08-2006, 10:41 PM   #4 (permalink)
q3_abhi's Avatar
Use Sound forge, its better.
q3_abhi is offline
Old 11-08-2006, 06:53 AM   #5 (permalink)
is there any free softwares?
Raaza is offline
Old 11-08-2006, 11:17 AM   #6 (permalink)
Thumbs up Re: Increase Sound Quality
AUDACITY is a great open source software similar to sound forge. try it.
prashanthnbhat is offline
- by gohan89
