Old 10-08-2006, 04:13 PM   #1 (permalink)
Question Memory (latecy) problem
I have p3 800mhz, 128 mb sdram, running windows xp. Recentley I purchased additional new 128mb sdram 133(dobleside chip). system work fine but at time of program setup (especially compress file) I get error messege crc fail or file currupt. I also tried microsoft memory test but no error found. I herewith attached cpuz snapshot file. pls suggest me any solution
Memory (latecy) problem-cpu-800.jpg   Memory (latecy) problem-mainboard-800.jpg   Memory (latecy) problem-memory-800.jpg   Memory (latecy) problem-spd-800.jpg   Memory (latecy) problem-spd-800-2.jpg
sagwde is offline
Old 10-08-2006, 04:44 PM   #2 (permalink)
siriusb's Avatar
Default Re: Memory (latecy) problem
How did you correlate crc error in a corrupt zip file and memory timings :s ? Both have no correlation (unless you tweaked the memory timings of course).
Most probably your setup file or the .cab files are corrupted somehow. Re-acquire the program from whereever you acquired it from and run the setup again.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 11-08-2006, 12:43 PM   #3 (permalink)
thanks for reply.
setup file is ok. Setup run smoothly using 128 mb ram but if I install 2 ram stick (128mb+128mb) I get error messege crc fail Or file currupt. pls suggest me another solution.
sagwde is offline
- by gohan89
