Old 10-08-2006, 01:33 PM   #1 (permalink)
coolsunny's Avatar
Default need help.
Hi guys,
need little help.
1. i cant remove safe remove hardware icon frm my startup.it shows my SATA hard dive- "ST3802110AS''.i tried to remove it with msconfig but in vain.but today i run "SISoftware Sandra" which i found frm this month's dvd & check Physical disks from hardware tab.then my comp restated instantly. it shows error msg 'ur system recovered frm serious ...' .Can any one tell me why this occured ? & how can i remove 'safe remove hardware' frm startup.
2.i want to make winxp starting up faster.want to do these 2 things below.
enable boot defragmentation, so that files used during start-up are clubbed together.
disable : "clear page file on shutdown" option
tell me how can i? plz help....
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 10-08-2006, 02:11 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: need help.
1.) Thats not a starup entry but seems some problem with either ur HDD or its drivers!
2.) Start -> Run and type regedit.
a.) Enable boot defragmentation: Nevigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOpt imizeFunction
in right-side pane, change the value of Enable to Y
b.) Clear pagefiles at shutdown: Nevigate to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Memory Management
in right-side pane, create DWORD value ClearPageFileAtShutdown and set its value to 1
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 10-08-2006, 08:23 PM   #3 (permalink)
coolsunny's Avatar
Thumbs up Re: need help.
thanks to Vishal.it is helpful.
Enable boot defrag is default set.For Clear pagefiles at shutdown..i have changed the value.
But my 1st problem is not solved yet. can any one help ?
Old 11-08-2006, 11:57 PM   #4 (permalink)
coolsunny's Avatar
my problem solved.
mods can close this thread.
- by gohan89
