Old 03-12-2004, 10:09 PM   #1 (permalink)
Default Sharing a dsl connection
ok here's an interestin question...
HOW IN THE WORLD DO I SHARE A DSL CONNECTION BETWEEN TWO COMPUTERS???
allright i have my comp. on the 2nd floor and my mom's comp. is on the 1st floor...how do I share my dsl connection with my mum???
Do i need a new modem or do i need something else?
hbk88in is offline
Old 04-12-2004, 05:54 AM   #2 (permalink)
Hi there , DSL or not what you need to do is attach two lan cards in the computer to which the internet is connected to and in one lan card connect the internet connect with whatever settings and IP address your ISP has assigned to you , then on the other card connect your computer and your mom's with a crossover cable (p2p) and assign a class c address like 192.168.0.1 and 192.168.0.2 and a subnet mask of 255.255.255.0 to each PC's and on your mom"s computer , in the default gateway option give the ip address of your computer to the lan card where the other end of the cable connects , that should work for you , any questions reply .Do give me feedback .
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 04-12-2004, 11:50 AM   #3 (permalink)
First & foremost which OS you got there at both ends?
If you got XP at one end then you can use Internet Connection Sharing[ICS] from the Network Setup Wizard to share your DSL connection after you've configured a proper LAN.
Let the machine decide IP for the 2nd machine,cause manually addressing IP on the second machine would be a better option cause 2nd machine will get internet access from the 1st one.The rest has been covered by indro.
www.Oobertech.net
digen is offline
Old 05-12-2004, 12:59 PM   #4 (permalink)
Im using Windows XP professional on my computer n on the other one ive got windows 98 installed..
thanx for the help.,...but after doin all this...can my mum use the internet when my computers switched off?
i mean when my computer's not connected...she wont be able to connect rite?
hbk88in is offline
Old 05-12-2004, 01:21 PM   #5 (permalink)
Nope she cant.Cause its like your computer is providing the necessary resources i.e dsl connection & your mum's pc is accesing the share.LAN has to be setup first & then ICS can be installed.
www.Oobertech.net
digen is offline
Old 05-12-2004, 01:24 PM   #6 (permalink)
allrightie then...thanx a lot.....!!!
hbk88in is offline
Old 05-12-2004, 02:11 PM   #7 (permalink)
anytime.
www.Oobertech.net
digen is offline
- by gohan89
