Old 08-08-2006, 12:56 AM   #1 (permalink)
Exclamation Problem with double click as well as enter
I m having a genuine problem. i hv a pc running ms windows xp, and whenever i try to open any icon by double clicking it, whether in explorer, or on desktop, the property window for that object opens up, ditto for selecting that item and pressing enter. PLZ HELP
sabr_villa is offline
Old 08-08-2006, 12:58 AM   #2 (permalink)
CG Artist
gaurav_indian's Avatar
Default Re: Problem with double click as well as enter
Maybe you have set the Click event on right click and and the pop menu or properties on the left click.Go to Control Panel and check mouse properties.
gaurav_indian is offline
Old 08-08-2006, 01:15 AM   #3 (permalink)
rahul_becks23's Avatar
this basic problem can be solved by checking some basic settings.
rahul_becks23 is offline
Old 08-08-2006, 06:18 AM   #4 (permalink)
eagle_y2j's Avatar
but wat type of basic settings?
Registered LINUX USER #438929
eagle_y2j is offline
Old 08-08-2006, 06:28 AM   #5 (permalink)
ummmmmmmmmmm...............maybe some basic tweaks frm Control Panel or some frm menu settings.................OR google it.
Old 08-08-2006, 02:43 PM   #6 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open regedit and for following keys:
HKEY_CLASSES_ROOT\Directory\shell
HKEY_CLASSES_ROOT\Folder\shell
HKEY_CLASSES_ROOT\Drive\shell
Make sure the value of Default is set to none, if its not then change it!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 08-08-2006, 03:48 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
check setting in control panel
if this dosent solve than
update ur driver for Mouse & Keyboard
satyamy is offline
- by gohan89
