Old 03-12-2004, 08:07 PM   #1 (permalink)
Default RAM Compatibility.....
I would like upgrade my ram ....... its a 256 MB PC 3200 DDR 400 MHZ ....
The thing is that i don't know the manufacturer ........ are ram modules from different manufacturers compatible with each other......... Please suggest some good companies.......
Strength of A MaN was Once mEasUred with his
BrAiN & bRawN ............ NoW its MeAsureD with hiS RAM & ROM !!!!
justo is offline
Old 03-12-2004, 08:48 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
well go on wid the upgrade
the ram modules are compatible as far as u buy the same speed ram stick
u can go for a Hynix 256 or a 512 mb DDR 400 RAM
Happy upgrading !
Sourabh is offline
Old 03-12-2004, 10:32 PM   #3 (permalink)
if ur gonna try duel memory setup then its recommended to use RAM sticks made by same company....
normally company name is printed on sides of dimm......try takin it out & readin
AMD Athlon 2500 XP, Asus A7N8x 2.0 Bios rev 1005, 1 x 512 mb Kingston PC3200 RAM, 1 x Western Digital WD200JB 200GB 8mb buff, 1 x Seagate ST380021a 80GB 2mb buff, 1 x Seagate ST3120022a 120GB 2mb buf, Ati Radeon 9500pro, Lite-on LTR-52327s, JLMS XJ-Hd165H
aunlead is offline
- by gohan89
