Old 06-08-2006, 10:28 PM   #1 (permalink)
readermaniax's Avatar
Default Computer Retarts During.......
I have a 3GHz Intel Pentium 4 Processor On a 865GBF Intel Motherboard with 512MB RAM And Windows Home Edition.
I Wanted To Convert a DVD into a 700Mb DivX Format File. For Doing This I used DivX Pro 6.2.5. The Video Got Analysed And started Converting But Suddenly The Computer Restarted.
Then What I Tried To do Was That I tried to Convert A Music Video ... I Got Converted ... Then I tried Converting More Music Videos And the Results Were Amazing!. Again I tried To Convert The DVD into A 700Mb DivX Format File, But Again It Got restarted.
So I thought It Might Be A heating Problem So I openedup my Cabinet and Cleaed Out All the Dust. I also Removed the RAM and Reilstalled it. Then I Went onto The Processor, There were 2 pins in it i opend them up but when i tried to pull up the fan it wont get deattached So i Left it. And Started my Computer.
Please Help Me!
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 06-08-2006, 10:36 PM   #2 (permalink)
shashank4u's Avatar
Default Re: Computer Retarts During.......
try using another software for conversion and then see if it restarts or not.
also use a temperature monitoring utility for yr motherboard from intel.com
see how much the temp rise before restart and post here.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 06-08-2006, 11:30 PM   #3 (permalink)
I have already Tried Using Dr.divx
Here Is the ScreenShot Of the Tempratures Before The Encoding:
Here Is the Screenshot Of the Tempratures During The Encoding Part 1 :
Here Is the Screenshot Of the Tempratures During The Encoding Part :
Old 06-08-2006, 11:36 PM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: Computer Retarts During.......
I think the problem lies with the software as i once experienced the same kind of problem using Dr.DivX but when i used other ripping tools,the sys didnt get restarted.
techtronic is offline
Old 06-08-2006, 11:53 PM   #5 (permalink)
shashank4u's Avatar
try divx convertor 6.1.2 ,or other software :try super if u can ,and then post again .
Old 07-08-2006, 12:22 AM   #6 (permalink)
[b]divx convertor 6.1.2[b]
COMPUTER RESTARTS
Old 07-08-2006, 12:39 AM   #7 (permalink)
shashank4u's Avatar
try converting with cabinet open,
use super for encoding and check.
just noticed one thing yr processor fan is the culprit here .
change it .
Old 07-08-2006, 06:57 AM   #8 (permalink)
My younger brother was having the same problem a few weeks ago and after seraching the net we remove Windows XP SP2 and it is now working correctly. Try that.
vikassethi is offline
Old 13-09-2006, 12:17 PM   #9 (permalink)
Exclamation Re: Computer Retarts During.......
I believe SP2 is the core reason for a lot problems with various softwares. I anyday would prefer a normal XP over XP SP2.
__________
And please do not play around with your processor.
slagad is offline
- by gohan89
