Old 03-12-2004, 12:56 PM   #1 (permalink)
Ethan_Hunt's Avatar
Default Kazaa Not Connecting
Well Need Help Fast guys......Today i just installed Kazaa Resurrection And since it didnt connect i uninstalled it and After that my Earlier installed Kazaa lite v2.4.3 Could not connect as well.....as it was working fine just a while ago.....I dont think this is a firewall probs so plzzz some Other opinions plzzz
Ethan_Hunt is offline
Old 03-12-2004, 05:33 PM   #2 (permalink)
Check the registry for correct entries
I faced this problem too, must be a registry problem.
The Comp is not recognising the program so this is happenning
Death keeps smiling at us all the time, all we can do is Smile back.
FasTrack is offline
Old 03-12-2004, 08:57 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
k-lite has been shut down
Sourabh is offline
Old 03-12-2004, 09:05 PM   #4 (permalink)
no its not shut dwon worked fine 4 me
had dat same prob
jsu changed my username, email into sum uda stuff like john@kazza or sumthing
and then just put a few files in ur shared folder if its empty or if only 1 or 2 files r dere
dis is all da stuff i did n it worked
mebe sum part isnt necesarry but i dono
mebe changin da username n stuff changed da regisrty n kinda refreshed it so da thing became fine agn....i dono all i kno is dat my kazaa works now
ishaan is offline
Old 04-12-2004, 12:23 PM   #5 (permalink)
Ethan_Hunt's Avatar
Thank God Saved from being Doomed.....It connected Just in a Few while....I suppose Just got a little Anxious for a while....anyways Thanks all u guys....and yeah Ishaan I suppose ur trick is handy for other Users as well thnx mate......
@Sourabh Don't Even Say that Kazaa has been Shutdown.....Its What My download is Survivng on right now.....lol
Old 04-12-2004, 05:08 PM   #6 (permalink)
Laptoping
Sourabh's Avatar
kazaa has become an out-dated p2p now
u cant trust it anyways
well its good for dialup users in india or mere smallband subscribers
i use e-mule for my downloads
Sourabh is offline
Old 04-12-2004, 07:42 PM   #7 (permalink)
Default Re: Kazaa Not Connecting
Most of Kaaza's Server have been closed, i might think thts ur core problem or else checking your proxy setting are right.
And You have mentioned tht, you have installed more than 2 - 3 types of kaaza.com. So registry must have been screwed.
Check them too
Regards,
Vinay
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
go4inet is offline
Old 05-12-2004, 11:20 AM   #8 (permalink)
Ethan_Hunt's Avatar
Dont Worry People i got is BAck online and is working like a breeze now.....Just like Old times.....
@Go4inet what Is Me Mentioning 2-3 Types of Kazaa.com .....WHat is said mate was that i had just Installed Kazaa Resurrection Instead of its previous Version...... 8) Anyways Thanks for Ya Help
Old 06-12-2004, 06:42 PM   #9 (permalink)
alib_i's Avatar
y do ppl get hyperactive on the name of KAZAA ..
yaar .. kazaa is old .. but its not dead ..
i still use it
half of junta simply discards kazaa by calling it old and unuseful..
but thats not so
i still find most of stull on kazaa which i cannot find on either DC++ or Bittorrent ( the latest p2ps .. as u wud say )
shareaza and emule are the nearest to database of kazaa
if u still find kazaa not connecting then pm me ..
i'll send u kazupernodes file
-Metallica
alib_i is offline
Old 08-12-2004, 10:31 PM   #10 (permalink)
I m having probs in connection to strong DC++, it does not search any files for me
Damm I am going off topic
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 09-12-2004, 11:49 AM   #11 (permalink)
Ethan_Hunt's Avatar
i still use it
but thats not so
What exactly does the kazaa supernode function do?????...i have it along with the kazaa lite tool pack......and one more query when it sasy more sources reuired or remotely qeued does it mean that the users have disconnected me from their side .....and yea Alib_i i agree with ya as kazaa is not dead at all...dun know why these people make so much fuss about it and compare it to that dumb sharezaa.....i have all my audio and video file contribution dedicated to kazaa itself.....much of it which i could hardly find on bit Torrent and Sharezaa and other P2P....anyways kazaa still rocks for me....
Old 09-12-2004, 03:15 PM   #12 (permalink)
alib_i's Avatar
go to
settings->strong dc++->client emulation->switch it to DC++
see if it helps
supernode is nothing but IP address of someone whu's running kazaa
supernodes which come with kazaa are IP addresses of machines where kazaa runs. there are a lot of ppl whu keep running kazaa. supernodes are collection of such IPs.
eveytime u connect to a supernode, the supernode list in your computer is flushed and refreshed.
not really .. may be you are not able to connect to them
or simply that .. lots of ppl are uploading from them .. and you have to wait in queue for the file
i agree man ..
kazaa's content is maximum .. more than any other p2p software
-Metallica
alib_i is offline
Old 09-12-2004, 04:29 PM   #13 (permalink)
Will try it alib_i
Will let ya know if it connects or not
- by gohan89
