Hi Guys I Just Installed Windows Xp Pro And I Installed Avast! Home Edition Version 4.7.
But My Windows Xp Pops Up A Balloon Saying That "avast!(v4.7)says That It Amy Be Outdated Click This Balloon To Solve The Problem"
What Should I Do
Plz Help
Tahnk You
KNOWLEDGE IS POWER!!:-)
If you really want to disable antivirus status notification, open control panel and open the security centre applet. click on virus protect and then on the recommendations button. There is a checkbox at the bottom saying "I have an antivirus product that I will monitor myself" Just check it.
But for heaven's sake make sure that your antivirus updates itself automatically.
