Hi every one,
I have transcend 512MB DDR400 MHZ RAM in my sys.
Now, I want to add another 1gb of RAM to it,but my friend says that I should add only 512MB RAM because I have only 512 MB ram in the other slot and my system will not be stable if I have 1GB RAM in one slot and 512MB in the other slot.
Is this correct?
If I add 1GB RAM will I get the full benefit?
thanks
Hi every one,
Is this correct?
thanks
Check the mobo manual and tell how many slots are empty.
