Old 02-12-2004, 11:01 PM   #1 (permalink)
Default Still photo from movie ?
would anybody like to tell me any software from i can take a still photo from movie (.dat)
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
imprince is offline
Old 02-12-2004, 11:42 PM   #2 (permalink)
swatkat's Avatar
Use PowerDVD or XingMPEG Player to take snapshot from the video files.
http://swatrant.blogspot.com/
swatkat is offline
Old 03-12-2004, 04:25 AM   #3 (permalink)
if u use XP and have windows movie maker installed, u can use it 2 capture screenshots
Nemesis is offline
Old 03-12-2004, 11:26 AM   #4 (permalink)
Pause the movie in full screen mode->press the print screen button->open Paint->paste the image->save it as .jpeg (or whatever extension you like).
But the resolution might not be that good if do it by this process, give it a try and check for yourself!
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 03-12-2004, 11:39 AM   #5 (permalink)
Bewitched!
xenkatesh's Avatar
That cant be done it will shows only black screen i tries a lot before.... :roll:
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 03-12-2004, 11:48 AM   #6 (permalink)
What are you saying dude? I've done it a lot of times too! :roll:
indrajit is offline
Old 03-12-2004, 11:52 AM   #7 (permalink)
it does't work man ... Think again and again thn do a practical before giving someone any example
जय माता दी
imprince is offline
Old 03-12-2004, 12:30 PM   #8 (permalink)
Still frame capture allows a user to capture a single frame of the movie, which cannot be achieved with the usual "Print-screen" key, as DVD players use a special overlay which cannot be captured normally. WinDVD's capture support is pretty limited - basically it will capture into a BMP file into the "capture" directory under WinDVD's installed directory once you press the capture hotkey or button. Unlike PowerDVD's implementation, you do not have the ability to capture to clipboard, instead of a file, nor do you have the ability to specify a location to store the captured file.
Source:The digital digest
WinDVD and PowerDVD have a snapshot option.You can specify the folder where captured images are to be stored and also specify the format in which the pic is to be stored.In WinDVD there is a "Camera" icon in the panel,click on it to capture the frame,alternatively u can use the hotkey assigned to this function,typically its "P" on ur keyboard......
P.S:u can chk out http://www.solidcapture.com/screen_capture_dvd.htm
I'm not a regular here but that doesn't make me a lurker :mrgreen:
ycr007 is offline
Old 03-12-2004, 12:35 PM   #9 (permalink)
Ethan_Hunt's Avatar
Why not go for the Best Bs Player This will Capture Everything u Need From .Dat to .Avi Files.....JUst Google for it Mate.....
@Indrajit Even i cant Get the image to paste in the way u suggested.....have done it a lotta times before but with the same blank screen reults.....same goes for the Screensavers.....I suppose Print Screen Does Not work For moving Images.....
Ethan_Hunt is offline
Old 03-12-2004, 01:23 PM   #10 (permalink)
Ok, a little addition to my post, I did it in Win98 and it works. I had not tried this on XP before and today whin I did try it didn't work out. So, I guess it works with 98 only. Sorry if anyone was mislead by my post.
indrajit is offline
Old 04-12-2004, 10:45 PM   #11 (permalink)
Default Try Nero ShowTime
Hi All
The complete Nero Ultra Edition includes the Nero VisionExpress 2 Pack which also includes, Nero ShowTime. This is a good video player esp. for DVDs and has an excellent screen capturing feature.
BTW, PowerDVD is not bad either...
Kinshuk
(o_0)
confused yet acting smartest of alll....
kinshuksunil is offline
Old 04-12-2004, 11:33 PM   #12 (permalink)
thnx friends for ur reply... everybody is talking about nero ultra edition ,,, i think i should try it ... thnx again
जय माता दी
imprince is offline
Old 08-12-2004, 10:43 PM   #13 (permalink)
It does work, all u need to do is turn the hardware acceleration of your graphics card to ZERO and ya I have done this practically many times
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 22-12-2004, 11:35 AM   #14 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
in which digit cd can i find WinDVD and PowerDVD ???
r they freeware ???
ax3 is offline
Old 27-12-2004, 10:03 PM   #15 (permalink)
@ax3: they aint freeware...both of them r commercial software.....but u usually get 1 of them with DVD-ROM drives....
Nemesis is offline
Old 28-12-2004, 11:50 AM   #16 (permalink)
tuxfan's Avatar
It depends on the graphics card and not the OS. It depends on how display is handled. I have only used Win98 so far. But could take a screen shot with print screen on my P3 300 machine. But couldn't do so on my P3 550 machine.
Are you sure? Wow!! Thats a great tip. I think I will try that out and see if it works.
tuxfan is offline
Old 29-12-2004, 02:26 PM   #17 (permalink)
Use PowerDVD or if u have corel suite.U can use Corel Capture.
Lovedeep Wadhwa
cheetah is offline
Old 03-01-2005, 03:17 PM   #18 (permalink)
whoopy_whale's Avatar
Use Jiao system's VCDCutter.That's the simplest way to extract a still frame from a movie.You can extract the image as jpg or bmp.
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 04-01-2005, 12:33 AM   #19 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmmm.. You can use the Capture option in BSPlayer .. great software ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 05-01-2005, 01:23 PM   #20 (permalink)
JaX
Use ULead Video Studio for all your video requirements...
Do things you've only dreamt of before....
JaX is offline
- by gohan89
