Old 04-08-2006, 06:34 PM   #1 (permalink)
Default DVD Writer & RAM
I have an old Compaq Presario Desktop PC with Abit BD-70G & Intel 845G with 128 MB DDR SDRAM working at 266MHz.I want to buy a new a 512MB RAM.Which type of RAM should i buy so that it doesn't conflict with my existing RAM.Please give me some details about the best DVD Writer that is available in the market.
Thank You
vineetrocks2005 is offline
Old 04-08-2006, 07:57 PM   #2 (permalink)
Official Techie's Avatar
Default Re: DVD Writer & RAM
liteon dvd writer is the best if u cannot find liteon go for sony dru 820a
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 04-08-2006, 07:57 PM   #3 (permalink)
varunpratap_singh's Avatar
The best thing you could do i find out which company's ram you are already using, and then go for the kill, but then however it really doesn't matter which one you chose. Just select the right speed and get that.
As far the writers are concered you can for the LG version or the latest one is from Samsung "octo edge". There's also versions of "Lite On" from "Lite Scribe" that allow you too print labels on your DVD's, but one sucker there, its only for the lite scribe dvd's. Man the best go for you is to go for the same speed RAM you already have and a samsung "octo edge". Burn'em hard.
Whenever i think i knew the answers they change the question.
varunpratap_singh is offline
Old 05-08-2006, 12:20 AM   #4 (permalink)
JGuru's Avatar
Go for a good brand RAM, also choose the same speed as yours. That's very important!!
As far as DVD Writer is concerned, go for Sony DRU-820A. It's the best one. Don't
buy SamSung drives (real troubles!!).
JGuru is offline
Old 05-08-2006, 05:52 AM   #5 (permalink)
I want 512 MB of RAM at 266Mhz,is it available or not...!
Old 05-08-2006, 12:26 PM   #6 (permalink)
It is dude, i'm usin it ryt now!
Old 05-08-2006, 07:41 PM   #7 (permalink)
ayush_chh's Avatar
i too was using a 128 mb Ram and then added 512mbs to it(both at 266MHz and same brand)only to find out that its a house of problems....the best u can do is take a 512mb ram at 333Mz if ur mobo supports. single mod is always better.....
ayush_chh is offline
Old 05-08-2006, 07:47 PM   #8 (permalink)
how much a 512MB RAM usually cost...!
Old 06-08-2006, 07:43 AM   #9 (permalink)
Pragadheesh's Avatar
Post Re: DVD Writer & RAM
Sony DVD writers are really good. You might get Tray problems in Samsung.
Pragadheesh is offline
Old 06-08-2006, 01:22 PM   #10 (permalink)
ayush_chh's Avatar
depends on frequency........anything above Rs. 1900
eXPerience is what a MAN learn's fROM.....
- by gohan89
