Old 04-08-2006, 03:48 PM   #1 (permalink)
Default registry editior disabled
whenever i try to open the registry editor
a msg pops up saying registry editor has been disabled
how should i enable the registry editor...
thadhanihemant is offline
Old 04-08-2006, 03:55 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: registry editior disabled
Start -> Run and type gpedit.msc, in:
User Configuration -> Administrative Templates -> System
Set Prevent access to registry editing tools to Not Configured.
PS: Also check ur system with a good anti-virus coz a virus also causes for such condition...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 04-08-2006, 04:15 PM   #3 (permalink)
i have a similar problem . when i press CTRL + ALT + DEL . i get the message " task manager disabled by ur admin " . it doesnt happen when i logon as another user ?
sagargv is offline
Old 04-08-2006, 04:18 PM   #4 (permalink)
Microsoft MVP
User Configuration -> Administrative Templates -> System -> Ctrl+Alt+Del Options
Change Remove Task Manager to either Not Configured or Disabled.
Old 04-08-2006, 04:20 PM   #5 (permalink)
sagargv is offline
Old 04-08-2006, 05:15 PM   #6 (permalink)
Console Junkie
aditya.shevade's Avatar
Thanks Vishal. I have a question... How did you find out about this stuff?
Aditya
aditya.shevade is offline
Old 09-08-2006, 07:45 PM   #7 (permalink)
thanks a lot !!
sagargv is offline
Old 09-08-2006, 08:19 PM   #8 (permalink)
Tech'ing life seriously!!
sude's Avatar
follow vishal ur prob will get solved...
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 12-08-2006, 05:24 PM   #9 (permalink)
thanks alot vishal my system was infected with
w32/rontokbro virus
now the problem is solved
sorry for replying late i wasn't able to do internet from the last
1 week becoz of the very hectic schedule............
thanks again
Old 12-08-2006, 09:05 PM   #10 (permalink)
Distinguished Member
anandk's Avatar
Aditya
vishals knowledge about the registry is quite impressive !
u too could build up ur knowledge about it by learning from his tips. also do refer the latest free registry tips booklet grom the digit mag. its xclnt.
also can download The Registry Guide for Windows from http://www.winguides.com/registry/
also check out WinTricks 4.0 from www.wintips-inc.com
incidentally u can always enable the task manager ALSO by adding the registry tweak from http://www.kellys-korner-xp.com/xp_tweaks.htm or http://www.dougknox.com/xp/utils/xp_emerutils.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 03-09-2006, 03:48 PM   #11 (permalink)
one more thing i want to ask u vishal
if we r using the home edition how we r going to enable the registry editor..
as there is no group policies in the home edition...
thanks...
Old 03-09-2006, 04:24 PM   #12 (permalink)
Microsoft MVP
How do you enable Registry Editing again if it has been disabled by your administrator?
Old 03-09-2006, 05:09 PM   #13 (permalink)
JGuru's Avatar
If it's a Registry hack, then ask @Vishal. He will solve your problem.
See, this guy resides in the Registry!!
JGuru is offline
Old 03-09-2006, 11:34 PM   #14 (permalink)
Microsoft MVP
thnx buddy for the compliment
Old 04-09-2006, 03:36 PM   #15 (permalink)
thanks vishal my problem is solved.....
thanks alot., u really live in the registry editor..
- by gohan89
