Old 04-08-2006, 04:16 AM   #1 (permalink)
zero's Avatar
Question Show Empty Folders in Different Colour
Hi Guys,
Is it possible via some trick or Mod that makes Windows Explorer to show empty folders in a different colour say 'Green' or anything other than normal yellow???
zero is offline
Old 04-08-2006, 10:37 AM   #2 (permalink)
siriusb's Avatar
Default Re: Show Empty Folders in Different Colour
That is an excellent suggesstion but there isn't any 3rd party app to do this yet. You can only manually and individually assign style. Or is there?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 05-08-2006, 12:27 AM   #3 (permalink)
JGuru's Avatar
You have to code in C++ using Windows API. That way check for all the folders, and
apply the different color to the folders that are empty!!
JGuru is offline
Old 05-08-2006, 07:44 PM   #4 (permalink)
ayush_chh's Avatar
i only know to assign colors to folders using VISTA tranformation pack...
ayush_chh is offline
Old 05-08-2006, 08:11 PM   #5 (permalink)
gooby pls
Third Eye's Avatar
try this software.
http://www.freedownloadscenter.com/M...our_Maker.html
Third Eye is offline
Old 05-08-2006, 08:34 PM   #6 (permalink)
Venom's Avatar
Isnt it already easy, just point your cusor and it says empty folder...
That software is called iColor, google it and you'll get it :]
From now on we are poison to you, that's why we call ourselves, the Venom!
Venom is offline
Old 06-08-2006, 01:54 AM   #7 (permalink)
zero's Avatar
Default icolorfolder
As suggested by Venom got this on googling but yet to try
http://icolorfolder.sourceforge.net/...older_page.htm
zero is offline
Old 06-08-2006, 01:24 PM   #8 (permalink)
ayush_chh's Avatar
thankz VENOM. will google it.....
eXPerience is what a MAN learn's fROM.....
- by gohan89
