Using Nero 5 I tried to create a multisession data disc.It went smoothly upto 4 sessions.After the 5th session,I am unable to access the data which I wrote.Even the volume label was changed.Only the data of 5th session is visible now. How can I retrieve the lost(actually still in the disc)data
In just two days, tomorrow will be yesterday.
Right click on the CD drive icon in My Computer and the got to Properties.Then property window go to "Volumes" tab and choose the volumes(or sessions written durin multisession burning) and click Apply to view the contents of that session.
If u are using XP then after Right Click>Property then u have to choose the CD Rom drive in the Devices list and then click "Properties".In the device's property window,u go to volumes tab and then click "Populate" to view the sessions.Then select the session required.
Hey! Swatcat mine sessions didn't came when i did ur sequence of operations in XP .. remember i have SP2 installed altoughi feel it hardly affects this but just for the sake of being enough explanatory /... plzz tell me how shd i look for my sessions!!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
Hmm.. That Property pages are displayd if you have Nero installed ..
Okay now to the problem .. You can use Isobuster to see what sessions had been burned on the CD .. Just extract the session or track that you want ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
Me 2 got this prob earlier... I comes when u write the sessions @ different speeds.
To get the missing sessions, write a new session with ur earlier speed, that'll show u the other missing files.
Try & experiment
