sure u can connect a pata and sata and backup !!
just as u would normally do it
not sure abt the ext. casing tho !! ... dun think so
give it a search on bazee !!
No Mercy, No Limits.
Sure you can do that. And dump the dumb PATAs quick. The performance gain is substantial. Not sure about the external USB thingy. But your drive is best inside the cabinet.
