Old 01-08-2006, 04:15 PM   #1 (permalink)
Random Scribbler !
wraj's Avatar
Default Of hard disk swappoing
hi mates,
Is it possible to load the operating system(preferably XP) on one machine and take out the hard disk and connect it on the another and have it up and running without any problem???Actually we are doing lots n lots of hard disk swapping at our hostel….It works flawlessly when slaved or connected as a master on IDE2 port but fails to work when treated alone…I thought there maybe the problem persisting with our hardwares??? So what say???
thanks in advance
www.amitwrites.com
wraj is offline
Old 01-08-2006, 04:22 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Of hard disk swappoing
If the HDD is used on same h/w config, then there should be no problem!
But if the h/w r different in both PC, then u might face problems, But afaik windows XP should install required drivers to run on both PC...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 01-08-2006, 04:22 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
may be if the hardware configuration of both the machines are same than it is possible
satyamy is offline
Old 01-08-2006, 04:27 PM   #4 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
yes it is possible.
n00b forever...
~Phenom~ is offline
Old 02-08-2006, 12:05 PM   #5 (permalink)
digiFriend's Avatar
if you swap hardisk and boot from it, different hardware might cease windowXp. once ceased, then it will not work on original pc also.
you never know what you can do until you try
digiFriend is offline
- by gohan89
