My Windows XP Professional with SP2 Is Installed in C: Drive !
Straight To the Prob..
I was editing registry, Successfuly Moved..
My Document,
Shared Document to D: drive!
I also found success in moving
Shared Picture to Shared Document in D Drive & Moving
Shared Music &
Shared Vedio to F: Drive.
Now to The Next stage;
I wanted to move my profile(Including the 'TEMP' folder) to My Document folder (Now in D: Drive)
So I edited Registry;
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Shell Folders]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\User Shell Folders]
I edited The Envournment Variable to move the Temp Folder. (My Computer > Properties > System Properties > Advanced > Envournment Variable)
But After That every thing Went Terribly Wrong I lost My
Shared Picture directory Where I had a Hell lot of Pictures & ......
Lots of problem Has Spawned;
1) Cannot Use Alt + Ctrl + Del , It says Task Manager Has Been Disabled by your Administrator.
2) Cannot Enable System Restore (Every Thing got turned off after editing registry)
3) Cannot Access Computer Managment !
If U need More Info please Tell Me.
Tried Reparing Using Windows XP CD But No Use
I tried moving the Profile using User profile Section (Windows Managment)
But, It takes a lot of time to logIn (So Dumped the Idea)
Can Any One Help ??? I Need some Expert's Idea !!!
