Old 31-07-2006, 09:18 PM   #1 (permalink)
Default burning xvid/divx files
now that i have a dvdrw. i want to know whats the best way to burn xvid/divx files to a cd/dvd so that they can be played back on a xvid compatible stand alone dvd player. shud i burn the files directly to the cd/dvd in the data cd mode or shud i first convert the files to vcd format and then burn. if i convert these files to vcd format will the file size increase?
neyo is offline
Old 31-07-2006, 09:57 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
Default Re: burning xvid/divx files
just burn the files directly.
dIgItaL_BrAt is offline
Old 31-07-2006, 10:28 PM   #3 (permalink)
Google Bot
Pathik's Avatar
burn in a data disc....
Pathik is offline
Old 01-08-2006, 06:27 PM   #4 (permalink)
can i use burn the files to a folder or do all the files shud be on the root folder?
neyo is offline
Old 01-08-2006, 06:57 PM   #5 (permalink)
mayanksharma's Avatar
Nothing man! Just and please burn the files. Dont think much. hehe.
mayanksharma is offline
Old 01-08-2006, 07:08 PM   #6 (permalink)
i didn't get u man and whats wit hehehe. u didn't answer my question.
neyo is offline
Old 01-08-2006, 07:49 PM   #7 (permalink)
royal's Avatar
Exclamation Re: burning xvid/divx files
Burn the files under root
royal is offline
Old 01-08-2006, 10:24 PM   #8 (permalink)
TechGuru#1's Avatar
Buy a DVD-RW & try out every other nethod as u think best.Mayb u can even teach us sumthing!!!
TechGuru#1 is offline
Old 01-08-2006, 11:00 PM   #9 (permalink)
i wud've done that if dvd-rw was cheap like a cd rw. btw i don't have a dvd player but planning to buy one. i've a collection of more than 100 movies and i want them to write it in a way to play em back on dvd player/
neyo is offline
Old 01-08-2006, 11:33 PM   #10 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
ONE QUESTION>>>
UR query is related to s/w or h/w ???
SO decide the ri8 section???
wizrulz is offline
Old 01-08-2006, 11:35 PM   #11 (permalink)
TechGuru#1's Avatar
AFAIK. price of DVD-RW's r less than 100 movies
why, don't you have something to do? why do you waste your time and my time. just answer my question or just don't reply. got it!
btw what a foolish reply "price of DVD-RW's r less than 100 movies"
i didn't buy em. i just downloaded em.
U Dull head,simply can't understand jokes or what?
Look for the sign b4 commenting
nuff said for the baachha!
Old 02-08-2006, 12:16 AM   #12 (permalink)
neyo is offline
Old 02-08-2006, 12:48 AM   #13 (permalink)
First of all you have to make sure that the player on which you want to play these files support which formats. Usually Divx is supported by current players but I doubt about Xvid since it is relatively new.
Kratos is offline
Old 02-08-2006, 12:54 AM   #14 (permalink)
You can see Divx and Xvid movies by writing them as data DVD disc. These movies can be viewed in any Divx supported DVD players
amit_50005 is offline
Old 02-08-2006, 12:25 PM   #15 (permalink)
Originally Posted by wizrulz
ONE QUESTION>>>
i can post it anywhere becos its a combination or both. but why argue over it. well this forum is here to help people nor argue abt it. got it.
neyo is offline
Old 02-08-2006, 05:40 PM   #16 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
I am not here to fi8 but i was instead helping u as u would be getting better and more ans in S/w section......
If ur a computer literate ..u would had known that its realated to S/w ...and u would had not argued......
Can u please enlighten me with ur knowledge how its related to h/w.....u said u have dvd writer ..means no question abt h/w and u want a way to burn movies on DVD which can be done by use of s/w and not H/w tweaks..... ........and next thing search be4 u post.....
By the way ur talking it seems this forum made a mistake having two diff sections as every s/w is used with comp h/w..so both r interalated ...is'nt it??
hmmmmm ya
wizrulz is offline
Old 02-08-2006, 06:00 PM   #17 (permalink)
Ethan_Hunt's Avatar
It dosen't matter if you burn them in a folder or out of it,the Xvid player will recognise the files instantly.Burning the disc in data mode for DVD's and VCD's is sufficient enough.
Yes of course.The codec compression from Xvid would be decompressed to Mpeg 1 format which would inflate the size.However if you do this then directly burn the disc in VCD mode using Nero as it dosen't matter if the file is over 700MB but the time must be within 80Min.Else you'll have to overburn the disc.
V for Vendetta
Ethan_Hunt is offline
Old 02-08-2006, 10:47 PM   #18 (permalink)
moshel's Avatar
the best and safest bet wud be to burn it using the Divx software
moshel is offline
- by gohan89
