Old 31-07-2006, 09:31 AM   #1 (permalink)
Console Junkie
aditya.shevade's Avatar
Question How to add a timer and background music in a C program?
Hi
I am attaching a program that I wrote in C.
I want to display a timer on the screen which will run till main is called back.
The time should be displayed when the number guessed is correct. (With the final output).
Can I add background music to this program? Ias there any way? (I am not talking of the sound(frequency) function, a music in maybe midi format like we do in html).
Aditya
The attached file contains following code....
#include<stdlib.h>
#include<time.h>
main()
int w,x=0,r1,r2,r3,r4,r5,r6,r7,r8,y,nc=0,pc=0,quit;
clrscr();
y = input(w);
r2=(y-y%10)/10;
r4=(r2-r2%10)/10;
r6=(r4-r4%10)/10;
if(y%10==r2%10||y%10==r4%10||y%10==r6%10||r2%10==r 4%10||r2%10==r6%10||r4%10==r6%10)
main();
if(y<1000||y>10000)
main();
if(y>999&&y<10000)
while(x!=y)
printf("\n\n\t\tEnter Your Choise Between 999 And 10000\n\n\t\t\t\t");
scanf("%d",&x);
if(x<10000&&x>999)
pc=0;
nc=0;
if(x%10==y%10)
pc++;
r1=(x-x%10)/10;
r2=(y-y%10)/10;
if(r1%10==r2%10)
pc++;
r3=(r1-r1%10)/10;
r4=(r2-r2%10)/10;
if(r3%10==r4%10)
pc++;
r5=(r3-r3%10)/10;
r6=(r4-r4%10)/10;
if(r5%10==r6%10)
pc++;
if( y%10==x%10||y%10== r1%10||y%10== r3%10||y%10== r5%10)
nc++;
if(r2%10==x%10||r2%10==r1%10||r2%10==r3%10||r2%10= =r5%10)
nc++;
if(r4%10==x%10||r4%10==r1%10||r4%10==r3%10||r4%10= =r5%10)
nc++;
if(r6%10==x%10||r6%10==r1%10||r6%10==r3%10||r6%10= =r5%10)
nc++;
printf("\n\n\t\t%d - Positions Correct",pc);
printf("\n\n\t\t%d - Numbers Correct",nc);
if(pc==4&&nc==4)
clrscr();
printf("\n\n\n\n\n\t\tThe Number You Asked Me To Guess Is \n\n\n\n\n\t\t\t\t%d\n\n\n",x);
printf ("\n\n\t\tPress 1 to play again or any other key to quit\n\n\n\t\t");
scanf ("\n\n%d",&quit);
if (quit==1)
main();
else
thankyou();
if (x==-1)
clrscr();
printf("\n\n\n\t\tThank You For Playing The Game. Hope You Enjoyed.");
getch();
abort();
if (x<1000||x>10000)
printf("\n\t\tThe Number You Have To Guess Is Between 999 And 10000");
else
printf("\n\n\n\n\n\tThe Number You Want Me To Guess Should Be Between 999 And 10000\n\n\t\t\t\t");
getch();
return 0;
input(u)
printf("\n\n\n\n\n\n\t\tPlease Press Enter To Start The Game\n\n\n\t\tIf You Want To Quit The Game Before It Finishes\n\n\n\t\tThen Enter The Number -1.\n\n\n\n\t\t\t\t");
getch();
randomize();
u = rand() % 10000;
clrscr();
return (u);
thankyou()
clrscr();
printf ("\n\n\n\t\tThank You For Playing This Game. See You Next Time");
getch();
abort();
return 0;
File Type: zip BULLCOWS.zip (967 Bytes, 3 views)
aditya.shevade is offline
Old 31-07-2006, 11:59 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: How to add a timer and background music in a C program?
i m getting errors wen compiling it...
Pathik is offline
Old 31-07-2006, 12:12 PM   #3 (permalink)
JGuru's Avatar
@Aditya, if you want to add background music like MIDI/WAV/MP3 use VC++ or JAVA.
Regarding the Timer:
This is how you do it. Use a for loop & use the sleep function, start this in a separate
Thread. Adjust the value for sleep() function , so that it works perfectly. It should
display 1 sec, 2 sec to 59 sec, 1 min. and so on.
JGuru is offline
Old 31-07-2006, 05:19 PM   #4 (permalink)
Console Junkie
@pathics
Which error are you getting?
Is it related to function declaration? If it is then please select the default type to c. ( I was having this problem when I saved the file as cpp in turboc and tried to compile it.).
Aditya
Old 31-07-2006, 05:27 PM   #5 (permalink)
Google Bot
Pathik's Avatar
yup i saved it as c.. i got 2 errors... fucn decl..
Pathik is offline
Old 31-07-2006, 07:50 PM   #6 (permalink)
Console Junkie
@pathiks
I have compiled the program and it's running it fine.
What is the message that you are getting?
I can't even give an exe file.
Aditya
- by gohan89
