Old 29-07-2006, 02:51 PM   #1 (permalink)
Mad and Furious
redhat's Avatar
Question How to launch applications from VB?
I am a newbie to Visual Basic 6.0. I want to know how to execute a exe file from a program made in VB. Please tell me where to get it from or get in touch with me at dar_nir@yahoo.co.in You can send me links or code samples or anything else. The exe file i want to execute was also made in VB if it does make some difference. I have its source also, but it is very confusing to add so many forms into the application.
redhat is offline
Old 29-07-2006, 03:18 PM   #2 (permalink)
Default Re: How to launch applications from VB?
try shellexecurte api
amitgg is offline
Old 29-07-2006, 09:35 PM   #3 (permalink)
ayush_chh's Avatar
try using OLE container.....
ayush_chh is offline
Old 29-07-2006, 11:18 PM   #4 (permalink)
puja399's Avatar
1) Easy approach --> ShellExecute API
2) Advanced approach (with much more control)--> CreateProcess API
puja399 is offline
- by gohan89
