Old 29-07-2006, 01:07 AM   #1 (permalink)
Ishan's Avatar
Default My Pc Starts on second attempt only.
->well when I start my PC after that Bios' beep sound it says "boot disk failure, Pls insert proper disk and restart.
But i restart without doing anything and it starts properly and i enjoy it as i am doing now since many Hrs.
but now suppose i need to restart my PC, and I press the restart option from shut down Dialog Box, the Pc wikk wikk start properly inthe first restart only.
But instead, If i do shutdown and wait for 2-3 mins and again start my PC the problem is same as arrow, and then again works fine on the next restart.
Pls Provide solution for this.
Now I tell u when this prob started from
previously I was having Win98 in C: and Win XP in D:
So i simply inserted Win XP bootable disk, and in the recovery console I did format C: and then format D:
it was done.
then first i did sys C: and then sys D:
then i restarted my PC with the same CD and did Win XP setup in C: drive.
since then this problem has started.
PC config:Intel celeron(R) CPU 2.06 Ghz, 256 Mb DDR Ram,
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 30-07-2006, 01:08 PM   #2 (permalink)
Ishan's Avatar
Default Re: My Pc Starts on second attempt only.
Hey Is there no one to solve my Prob? Or not clear with my prob.
Ishan is offline
Old 30-07-2006, 01:23 PM   #3 (permalink)
change the mobo battery
ashnik is offline
- by gohan89
