Old 29-07-2006, 01:06 AM   #1 (permalink)
Ishan's Avatar
Default what to do for the best browsing speed?
Well I want to browse web pages as fast as possible with my internet connection.
But my condition is I don't to change anything in hardware and dont want to install any internet boosting softwares.
I have
Win XP Professional version 2002
IE 6 and Mozilla Firefox 1.5
and am connecting thru Bsnl Dial Up
Now Pls suggest me the settings to do in these things. Well I use both the browsers so Pls provide settings for both these browsers.
I want settings like..
not showing images in the browsers
but when want to see any image while browsing, I can right click that image part(or small icon replaced for that image) and select an option to show that perticular image.
I dont want any type of show on my PC, Things must look as simple as they can and must open as fast as they can.
even i want my PC to run fast
I think u must have understood what i want to tell, tell me each and every setting possible. But these settings shouldnt harm my PC's hardware. I dont want to spend a single Rupee on this.
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 29-07-2006, 01:46 AM   #2 (permalink)
deathvirus_me's Avatar
Default Re: what to do for the best browsing speed?
Well .. Google for the list ... or visit http://www.tweakguides.com/
deathvirus_me is offline
Old 29-07-2006, 11:21 PM   #3 (permalink)
puja399's Avatar
I think for getting best browsing speed, u need to take Broadband.
puja399 is offline
Old 29-07-2006, 11:31 PM   #4 (permalink)
foreign return(0)
comrade's Avatar
if firefox is your browser...
1. Type "about:config" into the address bar and hit enter. Scroll down and look for the following entries:
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it recieves.
More options:
For ADSL:
1. Type: about:config
2. Set:
network.http.max-connections : 64
network.http.max-connections-per-server : 21
network.http.max-persistent-connections-per-server : 8
network.http.pipelining : true
network.http.pipelining.maxrequests : 100
network.http.proxy.pipelining : true
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it recieves. (Copy from TvM)
For Dial_ip:
browser.cache.disk_cache_ssl : true
browser.xul.error_pages.enabled : true
content.interrupt.parsing : true
content.max.tokenizing.time : 3000000
content.maxtextrun : 8191
content.notify.backoffcount : 5
content.notify.interval : 750000
content.notify.ontimer : true
content.switch.threshold : 750000
network.http.max-connections : 32
network.http.max-connections-per-server : 8
network.http.max-persistent-connections-per-proxy : 8
network.http.max-persistent-connections-per-server : 4
network.http.pipelining.maxrequests : 8
nglayout.initialpaint.delay : 750
plugin.expose_full_path : true
signed.applets.codebase_principal_support : true
comrade is offline
Old 30-07-2006, 01:22 AM   #5 (permalink)
knight17's Avatar
This will not help you a lot..but give it a try
Defrag the HDD...as this will help to improve the speed of files loading from cache.
If speed is what you want go for Opera..it has features and is light on resources too..
"It's not a silly question if you can't answer it." Sophie's World [ http://en.wikipedia.org/wiki/Sophie's_World ]
knight17 is offline
Old 30-07-2006, 02:40 AM   #6 (permalink)
PrinceHeart's Avatar
Have a look at this : http://www.tune-up.com/products/tuneup-utilities/
This might solve some hidden PC errors.
peace
*PrInCe*
PrinceHeart is offline
Old 30-07-2006, 07:46 AM   #7 (permalink)
eagle_y2j's Avatar
Question Re: what to do for the best browsing speed?
+1 nd Google web accelerator can also help a little !
Registered LINUX USER #438929
eagle_y2j is offline
Old 30-07-2006, 10:25 AM   #8 (permalink)
gooby pls
Third Eye's Avatar
try opera 9.
Third Eye is offline
Old 30-07-2006, 01:00 PM   #9 (permalink)
Ishan's Avatar
Ok,
Just yesterday, I defragmented my PC and did a PC cleanup
Even I have Google Web accelerator in both firefox and IE ^
also the settings of about: config in firefox is done by me be4 two months..
I also have Broadband....But dial up too! When my 1 GB limit finishes, i use dial up as a spare..
So pls suggest more suggestions..
Ishan is offline
Old 30-07-2006, 02:29 PM   #10 (permalink)
you clearly need some tweaking tools. Try this forum on tweaking help and also google for tweaking your pc. You will get lots of results. Happy reading
cheerz
*PrInCe*
Old 31-07-2006, 12:35 AM   #11 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Firefox + Adblock Plus & Filterset.G Updater ..
rollcage is offline
Old 31-07-2006, 01:46 AM   #12 (permalink)
knight17's Avatar
It is just another non working software you wont get any results.
knight17 is offline
Old 31-07-2006, 01:52 AM   #13 (permalink)
Thumbs up Re: what to do for the best browsing speed?
you can use Tz cinnection booster.
also you can try this
go to start>run>type gpedit.msc
from there browse to local computer policy >administrative template>network>qos packet scheduler> limit reservable band with and then click on enabled and set the limit % to 0. you will surely notice some improvement in speed as it disables the bandwith limit windows reserves for auto updates.
wanna get the best processor, look inside your head
rajat is offline
Old 31-07-2006, 09:39 AM   #14 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
hey rajat......
can v use the above only for win XP /????
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 31-07-2006, 12:01 PM   #15 (permalink)
Google Bot
Pathik's Avatar
no apps ll really increase ur speed....
Pathik is offline
Old 31-07-2006, 12:04 PM   #16 (permalink)
JGuru's Avatar
Use FireFox & Here are the Things that will make pages load faster!!
* Install the FireFox extensions 'FasterFox, 'AdBlock', 'NoScript' & other ones you
need. Get it from here : https://addons.mozilla.org/firefox/
* Configure the 'AdBlock' by right-clicking on its icon (at the bottom right statusbar)
Choose Options . And that dialog box that pop type '*' .This means all Ads from
the Website are blocked!!
* Also configure FireFox to 'Load Images from the originating site only'.
You can do that in the 'Options' dialog.
JGuru is offline
Old 31-07-2006, 01:42 PM   #17 (permalink)
rahul_becks23's Avatar
This is my guide for the best browsing speed on this planet-
-Start-
Get Opera.
-End-
rahul_becks23 is offline
Old 31-07-2006, 01:48 PM   #18 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Yeah man,
Opera 9 really rocks on my dial up.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 31-07-2006, 03:32 PM   #19 (permalink)
Come get Some
DukeNukem's Avatar
Windows XP reserve 20% of the bandwidth you use while browsing
disable this on usin gpedit.msc and see the result (shoul gain the speed)
to dissable it enable it to 0%
as i cant open it on my pc due to some error i am unable to give the steps
any body here can she light on this to help this chap
Shake it baby
DukeNukem is offline
Old 31-07-2006, 03:40 PM   #20 (permalink)
Google Bot
Pathik's Avatar
hey duke i know wt u r talkin abt...
but even that wont work....
Pathik is offline
Old 31-07-2006, 05:37 PM   #21 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Well here's what i did when on dialup :
Disable Images , Scripts And Java . ( on the content tab in options in firefox )
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 01-08-2006, 08:51 AM   #22 (permalink)
Ishan's Avatar
this is great...I didnt load images ...
Well I tried this in IE...but the Page looked worse...So I returned to original setting...But in Firefox...It rocks!...
Ishan is offline
Old 15-08-2006, 12:43 AM   #23 (permalink)
Red face Re: what to do for the best browsing speed?
you are correct Indyan. when we open gpedit to configure the QOS packet scheduler it shows that reservable bandwidth is NOT CONFIGURED.. REGARDING CONNECTION SPEED IN DIALUP the main thing is the traffic in your locality or local telephone exchange. not the regular phonecalls but the traffic in internet usage. in my locality i am perhaps the last person who uses dialup and while i am writing i am getting getting a connection speed of 52 kbps and i download pages at 4 kbps speed at an average with all the features in opera 9 turned on. this is a thing which no software can help. solution: go for broadband. or use a download manager to download in dialup. and opera is the best in such a situation. i have tried all the popular web browsers and i preffered to stick with opera along with free download manager 2. thanks
rajat is offline
- by gohan89
