Old 28-07-2006, 09:33 AM   #1 (permalink)
TechTin.com
ravi_9793's Avatar
Default unablt to unistall programs
frnds.........
I am using window XP pro. sp2.
I think my system is infected from sm virus...and so my antivirus is nt working.
I am using mcafee suit.
Now I am trying to uninstall the mcafee suit and reinstall it again....but whenever I try to unistall it ...it fails.
How can I uninstall it....plz help.
ravi_9793 is offline
Old 28-07-2006, 10:12 AM   #2 (permalink)
Default Re: unablt to unistall programs
Have you tried to uninstall it in safe mode? If that fails, second thing to try is to reinstall McAfee over itself and then uninstall it (again, do this in safe mode if you think you have virus problem). Third option, delete McAfee folders and use a registry cleaner.
Arun
sakumar79 is offline
Old 28-07-2006, 10:48 AM   #3 (permalink)
Google Bot
Pathik's Avatar
delete the mcafee folders ...
go to regedit search for its entries ...delete all its values.... and reinstall it
Pathik is offline
Old 28-07-2006, 11:30 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yaa..i have done to overinstall mcafee...but that also failed.
However I havnt tried in safe mode.
I will try in safe mode ...than I will post wht happened.
Hey frnds..kindly tell me the way to delete from registry...all its entries.
Old 28-07-2006, 12:07 PM   #5 (permalink)
the deconstructionist's Avatar
You can use cc cleaner after you have uninstalled it.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 28-07-2006, 01:05 PM   #6 (permalink)
ionicsachin's Avatar
Hey man ur PC is affected by W32.Jeefo. It corrupts all the uninstallation data.
To make it sure about Go to Start>Run and type %windir%
If a file called svchost.exe is present in this folder than the Jeefo is for sure.
Search on google for removal tool.
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 28-07-2006, 01:50 PM   #7 (permalink)
shanket's Avatar
Delete the folder...
Then goto regedit and delete all values and variable associated to mcafee.
And your system is not infected by a virus. It often happens with mcafee, if its not up to date....
shanket is offline
Old 28-07-2006, 01:58 PM   #8 (permalink)
SE><IE
Posts: n/a
delete all MCafee folders from program files.
Then head up to regedit and browse to
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr ent VErsion\Uninstall
search for mcafee's registry there and delete it.
search for mcafee's entries by pressinf ctrl-F( in regedit) now write mcafee and search. lather, rinse, repeat
Old 28-07-2006, 07:26 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
svchost.exe is nt present here.
Old 31-07-2006, 11:18 PM   #10 (permalink)
shashank4u's Avatar
one thing u can do is to go to symantec.com
and online check yr system for virus.and then find virus removal tool.
simple.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 01-08-2006, 12:08 AM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
simple.
arre yaar.............
I have removed the mcafee by deleting its folder and registry filesand i have installed quick heal antivirus.
I have scanned my computer .
But still unable to install the mcafee suit.
Old 01-08-2006, 12:12 AM   #12 (permalink)
shashank4u's Avatar
else u have no choice man.
Old 01-08-2006, 12:14 AM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
ok man..........
i will try to find the sol. myself...whnever i will get sufficient time.
Old 01-08-2006, 12:26 AM   #14 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
I think these 2 links should help U:
http://www.wikihow.com/Uninstall-McAfee-Security-Center
http://discussions.virtualdr.com/sho...d.php?t=195422
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
