Old 27-07-2006, 08:54 PM   #1 (permalink)
Angry cannot capture picture in tv tuner card
I have techcom tv tuner card. win xp, 512md ddr,
for few months i was able to captur picture smoothly by tvtuner.
but after formating the comp i am not able to do so. whenevre i try to record it gives me massage cannot start record. i tried to change the formate and foud that i was able to record in only avi formate that also at very low frame rate. my tv tuner support mp2,mp4 and others. i alsotried buy installing codec,reinstaling sdriver,tvtuner software,direc x latest.
what is the prob????????
bkpeerless is offline
Old 27-07-2006, 09:19 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: cannot capture picture in tv tuner card
make sure that the wires are connected correctly tp cpu and whihc software are you using for tv tuner.
Third Eye is online now
