Old 27-07-2006, 01:13 AM   #1 (permalink)
No longer here..
Default can we pair two .....
Hi,
I wanted to ask ..
I have one pc and one telephone line thro which i get adsl...
my friend has the same setup....
can we somehow combine the two so that we can get combined speeds that is double the individual speed.
If yes then kindly suggest a way.
indian_samosa is offline
Old 27-07-2006, 02:40 AM   #2 (permalink)
rahul_becks23's Avatar
Default Re: can we pair two .....
search the forum
rahul_becks23 is offline
Old 27-07-2006, 11:55 AM   #3 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
According to me to double the speed is not possible by the way u suggested..........
1.) in order to connect the 2 pcs u'll need a connection between the 2.... which will act as a bottleneck.....
2.) moreover u can install a software such that the data U send will be managed........ but what abt the data that the server sends u.......which way will it send?????to ur pc or ur friends pc.....
3.)then there will be security issues.......if a pack of data is sent thru ur computer to his ..... then u can view it....and change it........
see its not as simple as 2+2=4....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 27-07-2006, 01:39 PM   #4 (permalink)
No longer here..
thanks for ur prompt reply vandit..
Old 27-07-2006, 08:18 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
i dont think ...this will increase the speed.
ravi_9793 is offline
