Old 25-07-2006, 12:29 PM   #1 (permalink)
aniishvara@gmail.com's Avatar
Smile a small c problem
i have 2 questions in my book for which i am not able to decide on the exact solution..
? 1- write a program to accept any number upto 6 digits and print that in a string.
Eg:
input number 1034
output string one thousand thirty four
? 2- write a program to accept any date in numbers annd print that in string
Eg
input date: 19/3/96
output string nineteen march ninety six.
aniishvara@gmail.com is offline
Old 25-07-2006, 02:51 PM   #2 (permalink)
I see right through you.
Sykora's Avatar
Default Re: a small c problem
Since it's probably a homework question, I'm not going to give the answer as code.
In both, you need to extract the digits one by one, and display accordingly.
Use a loop to extract the digits, and store them in variables. Then output them after the loop has finished.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 25-07-2006, 03:56 PM   #3 (permalink)
nik_for_you's Avatar
use of arrays,pointers will help you .. had done both programs in past.. try it own dear
I AM REBEL
nik_for_you is offline
Old 25-07-2006, 05:15 PM   #4 (permalink)
tuxfan's Avatar
I am glad you guys didn't give out the code This surely is a homework problem! Solve it on your own man! These guys have given you enough hints!
I have done this in COBOL when I learnt it You can't do it in C? Try it. Its easy. You can do it.
tuxfan is offline
Old 26-07-2006, 12:28 AM   #5 (permalink)
Thumbs down Re: a small c problem
hey guys @ least tell me how to go abt that 18 ,19 etc nos...
ie how do i print the appropriate string saying eighteen ,or one or two,,,
for all the dates in a month!!!
Old 26-07-2006, 09:08 AM   #6 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
get each number and its place(ones place, tens place, hundreds place etc) and write a function to convert a number to text (basic like 9-nine) and add suffixes based on the place. remember there are lots of exceptions in this pogram because 18 is eight-een and 17 is seven-teen but 11 is not one-een. get what I'm saying? this confusion is only in 2 digit numbers till 20, so from that its easy
dheeraj_kumar is offline
Old 26-07-2006, 09:17 AM   #7 (permalink)
Console Junkie
aditya.shevade's Avatar
Are you suggesting using the % (reminder tag?)
Aditya
aditya.shevade is offline
Old 26-07-2006, 10:25 AM   #8 (permalink)
Unhappy Re: a small c problem
no ...u r not right!!! cos i have to print it as eleven for 11 , and not split the numbers as one one or for that matter 18 as eight-een
any numbershould be printed as we read it
like eighteen, 25 as twenty five itself and not like two-five as stated by u!!!
c this is the problem..and i do not want to use some stupid switch case or some else if ladders to print it appropriately!!!
Old 26-07-2006, 10:37 AM   #9 (permalink)
hi tuxfan, so u know to code programs in cobol , cud u pls suggest me some ebooks, or tutorials on cobol cause i'm also learnin COBOL, for AS 400 and mainframes.
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 26-07-2006, 11:40 AM   #10 (permalink)
Extract the last two digits: for one to twenty they have to have separate switches, for above twenty, you put one switch for each of the two digits. Then, go to the next digit for hundred, and so on...
Arun
sakumar79 is offline
Old 26-07-2006, 02:37 PM   #11 (permalink)
tuxfan's Avatar
That was many years ago! I don't remember anything in COBOL now. Completely out of touch
tuxfan is offline
Old 28-07-2006, 10:19 PM   #12 (permalink)
Beware of the innocent
ilugd's Avatar
@paul
http://www.csis.ul.ie/COBOL/
http://www.freeprogrammingresources.com/coboltutr.html
http://www.programmingtutorials.com/cobol.aspx
ilugd is offline
Old 28-07-2006, 10:54 PM   #13 (permalink)
puja399's Avatar
Create a dictionary in an array, and u don't have to use 'case' or 'else if ' ladders.
puja399 is offline
Old 29-07-2006, 11:13 AM   #14 (permalink)
Question Re: a small c problem
wat is a dictionary in an array???
and how wud u create a dicitonary in an array???
Old 29-07-2006, 01:07 PM   #15 (permalink)
Sykora's Avatar
Methinks puja399 is confused, dictionaries are native python...or so I believe.
-- Sykora --
Sykora is offline
Old 29-07-2006, 05:22 PM   #16 (permalink)
ilugd's Avatar
c or c++?? @puja??
ilugd is offline
Old 29-07-2006, 10:07 PM   #17 (permalink)
I think puja means that you use dictionary classes/templates to work with... Something such as http://www.codeguru.com/cpp/cpp/cpp_...icle.php/c869/ indicates... Creating maps will reduce the work in if-then-else clauses...
Arun
Old 29-07-2006, 10:57 PM   #18 (permalink)
God of Mistakes...
Garbage's Avatar
I think he should first check the number of Digits in given input.
ex. 10,286. Here it is 5. Hence the output string must contain "Thousand".
Then it is easy to write the code. Bcoz TEN is same for Lacks, Hundreds & TEN also.
Isn't it?
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 29-07-2006, 11:14 PM   #19 (permalink)
puja399's Avatar
Arun
Exactly so, however, u can implement a simple map in C using a 2D array.
puja399 is offline
Old 30-07-2006, 03:56 AM   #20 (permalink)
Official Techie's Avatar
Why don't you start a new thread for your problem? Don't hijack threads
-tuxfan
i have a problem in c++
#include<iostream.h>
class outer { int a;
class inner {
int b;
public:
int c:
void prn(void)
cout<<endl<<"inner :: prn()"<<endl;
cout<<b<<c<<endl;
inner()
b = 5;
c = 10;
inner ob1;
public:
inner ob2;
void second(void)
cout<<endl<<"Outer::second()"<<endl;
cout<<ob2.c<<endl;
cout<<"A = "<<a<<endl;
ob1.prn();
outer()
a = 25;
void main()
outer ab;
ab.second();
ab.ob2.prn();
the errors are
--------------------Configuration: example of nested class - Win32 Debug--------------------
Compiling...
example of nested class.cpp
D:\Documents and Settings\Sudipta\school\c++\example of nested class.cpp(7) : error C2062: type 'void' unexpected
D:\Documents and Settings\Sudipta\school\c++\example of nested class.cpp( 8 ) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
D:\Documents and Settings\Sudipta\school\c++\example of nested class.cpp(39) : error C2039: 'prn' : is not a member of 'inner'
D:\Documents and Settings\Sudipta\school\c++\example of nested class.cpp(3) : see declaration of 'inner'
Error executing cl.exe.
example of nested class.obj - 3 error(s), 0 warning(s)
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 30-07-2006, 06:52 AM   #21 (permalink)
I think in line 6, the end of the statement you have given : instead of ;. Change it and check.
Arun
Old 30-07-2006, 07:30 AM   #22 (permalink)
thanks a lot but this was a very silly mistake
Old 30-07-2006, 11:09 AM   #23 (permalink)
tuxfan's Avatar
Isn't it?
I think he will be better off converting the string to numbers first! So that if someone plays a mischief by entering say a string like "A5463" then the program doesn't process it at all.
Secondly, here're 2 hints!
Use the mod operator %
Use arrays with the strings "twenty" "thirty", etc.
Use some more arrays and variable of course. I guess these hints are enough
tuxfan is offline
