Old 25-07-2006, 12:14 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default How to delete logical drive & reclaim free space?
I was using Win XP with Linux earlier. Linux had created a swap drive of 407MB (h:\). After I formatted my sys., h: appears as logical drive with NTFS file sys. Other drives use FAT 32. I no longer use linux.
Now how do I delete H: and allocate the free space of 407MB to f: (g: is combo drive). If I delete the h: drive thru disk management, 407MB appears as free space. I want to utilise the free space. How do I do that?
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 25-07-2006, 12:27 PM   #2 (permalink)
Wink Re: How to delete logical drive & reclaim free space?
You may can use Partition magic software which will remove this partition and than u can create windows partition.
laptops4u is offline
Old 25-07-2006, 01:17 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: How to delete logical drive & reclaim free space?
Ya as laptops said use any partiton utility like Nrtn Partiton Magic or powerquest Partititon Magic..It will dfntly solve ur problem
rakeshishere is offline
Old 25-07-2006, 03:59 PM   #4 (permalink)
nik_for_you's Avatar
after deleting through disk mgmt you can create new partition from it too.
or you can use fdisk utility of 98 bootup disk its very nice
I AM REBEL
nik_for_you is offline
Old 25-07-2006, 04:38 PM   #5 (permalink)
hansraj's Avatar
take a 98 or me bootable disk and in the command prompt give command
fdisk
this will take u to options of deleting all the drives one by one and then do a full format again reassign the drives as u want
hansraj is offline
Old 25-07-2006, 04:52 PM   #6 (permalink)
!FREEWARES!
Akshay's Avatar
I have tried formatting and deleting the drive thru disk mngmt. What I want is that the free space so created shud be reclaimed by any of the c:, d:, e: or f:. Can this be done by some utility in XP itself as I dont want to download any additional s/w at the moment?
Also the data in any other drive shud not be affected by this...
MBP 13.3";
Akshay is offline
Old 25-07-2006, 05:02 PM   #7 (permalink)
Google Bot
Pathik's Avatar
nope i dont think u can resize partitions using XP....
better use partition magic
Pathik is offline
Old 25-07-2006, 05:15 PM   #8 (permalink)
!FREEWARES!
Akshay's Avatar
If I use partition magic, will my data on f: be lost? or only free space of 407mb will be added?
MBP 13.3";
Akshay is offline
