Old 25-07-2006, 11:26 AM   #1 (permalink)
plsoft's Avatar
Default Partition new hard disk!!
Please tell me everything about partitioning a NEW hard disk, from softwares required to the HOW TOs.
plsoft is offline
Old 25-07-2006, 11:53 AM   #2 (permalink)
ayush_chh's Avatar
Default Re: Partition new hard disk!!
if u hav winXP bootable disk just boot ur system from it and follow the instructions.(for a MASTER DRIVE)
if u r goin to use it as slave. then use windows 'disk manager'
to open it
Click Start, click Run, type compmgmt.msc, and then click OK
if u r booting from MS DOS then type 'FDISK' for disk management
this type of threads hav already been opened a million times.
click here
ayush_chh is offline
Old 25-07-2006, 12:04 PM   #3 (permalink)
yes just insert winxp bootable and follow the instru.
sanju is offline
Old 25-07-2006, 12:22 PM   #4 (permalink)
JGuru's Avatar
If your harddisk is Seagate use Seagate's 'Disk Wizard Starter Edition' CD or
download & burn the ISO image file in a CD. Or you can use Windows XP bootable
CD also for the same.
JGuru is offline
Old 25-07-2006, 07:05 PM   #5 (permalink)
plsoft's Avatar
thnx guys
plsoft is offline
