Old 25-07-2006, 09:23 AM   #1 (permalink)
Default sound
after i format my com.how come my i cant detect sound card...ahmm is there any software about sound card installation???help need ..
newbies is offline
Old 25-07-2006, 09:29 AM   #2 (permalink)
Default Re: sound
Does your motherboard come with a built-in soundcard? If you did not purchase one, but still have the three ports (usually one green, one pink and one black) on the back of the CPU, that would be the case. Take out the driver CD for your motherboard. The drivers for the soundcard are contained in it...
If you dont have a CD, you can download it from sites such as www.driverguide.com etc. If you dont know the motherboard model, you will need a util such as Everest or Sisoft Sandra to find it out.
Arun
sakumar79 is offline
Old 25-07-2006, 12:14 PM   #3 (permalink)
The Researcher
Default Re: sound
If you have realtek ac97 soundcard in your motherboard, download it's driver and install. You may consider using driver magician software which will back up all non-microsoft drivers. This will help you in situations like this.
Ramakrishnan is offline
