Old 23-07-2006, 01:36 PM   #1 (permalink)
NEXT BILL GATES
mihirvashist's Avatar
Question how to burn iso CDs
what the question suggests
HOW TO BURN IOS CDs FOR AN OS(BOOTABLE)
KNOWLEDGE IS POWER!!:-)
mihirvashist is offline
Old 23-07-2006, 01:40 PM   #2 (permalink)
go_gamez's Avatar
Default Re: how to burn iso CDs
u should already have a bootable .iso image to burn it..if u have an .iso image just open it with nero burning rom/nero express and u can burn it..
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 23-07-2006, 02:12 PM   #3 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Burning .iso files is simple. To burn a bootable image you must have a bootable image. You can burn it in nero by selecting Open files and then select the file type to "all files" and then selecting your image file.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 23-07-2006, 02:15 PM   #4 (permalink)
NEXT BILL GATES
Question Re: how to burn iso CDs
how to create bootable .iso image
Old 23-07-2006, 02:43 PM   #5 (permalink)
Level 96 Headbanger
It is easy to create Bootable ISO images with softwares which support them. In Nero Express, to create a bootable ISO image, go to Data disc>Bootable disc, on the main menu. When you are done with adding your files, click next. On the next screen, Enter the Boot image path or alternately select the preset image (usually United States will do), then click next. When asked the name for the image file Select file type as ISO and enter a name and click OK.
There you have an ISO image of your own.
Best of Luck!
Steam : DeathMetal
Old 23-07-2006, 02:51 PM   #6 (permalink)
Google Bot
Pathik's Avatar
and mihir most of the OS isos u get r bootable only...
to create a bootable iso 4m a normal iso with nero u need a bootable floppy.....
Pathik is offline
Old 23-07-2006, 02:55 PM   #7 (permalink)
NEXT BILL GATES
Best of Luck!
thnx
will try it as soon as possible
