Help me in checking the hosted web server by Sybss WebServer
I am having the following error:
You do not currently have a default document set for your users. Any users attempting to connect to this site are currently receiving an "Under Construction page".
i have installed the abyss Web Server and while writing 127.0.0.1 in the URL address bar.
and also help me to know how to run php and where to do programming in it.
check if that ips loads ur website. You may need to edit LAN and internet connection firewall settings.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
Re: Help me in checking the hosted web server by Sybss WebServer
1st of all are u trying to host a website from ur location or just want to instaall a web server to check ur php programing...??
if it is the second one then easyphp.org is the answer of u... it will install apache... php... and mySQL to run them from localhost or http://127.0.0.1/
