Old 22-07-2006, 11:31 PM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Default Online Radio queries?
I use Winamp. Is it possible to save the audio files that are streaming through online radio? Is there a s/w for tht? While i am listening to online radio, does downloading takes place?
http://twitter.com/blueshift155
blueshift is offline
Old 22-07-2006, 11:59 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: Online Radio queries?
Sometimes i get to dwnld the documents,videos ,songs in some site to get actualy get dwnld through IDM-Internet download manager which are only meant to see or listen in the site...This s/w catches the link somehow and the files like music,videos get dwnld
And for online radio the buffering happens and the file is not dwnld...It is actually streamed music via the internet media
rakeshishere is offline
Old 23-07-2006, 12:03 AM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
What does buffering mean? Doesn't it happen at the host pc?
When i right click the streaming radio in Winamp the Network Received bytes goes on increasing. Tht means something is downloaded! Clarify me plz.
Old 24-07-2006, 02:37 AM   #4 (permalink)
HELP AND SUPPORT
Smile Re: Online Radio queries?
Dnwld means u save the music in ur comp and then u play it while buffering means it is actually played from the server which hosts the radio station...Its not actually dwnld but is played through the internet network to ur system
Old 24-07-2006, 04:22 AM   #5 (permalink)
When the buffering takes place, it's actually saved on ur hard drive temporarily. If played on the Media Player, they are saved in the Temporary Internet Files folder. Donno about Winamp.
But, there are other fine FM Players that play and give you the options to actually save the streaming audio in real time.
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 24-07-2006, 01:25 PM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
So anyways it is going to add to my downloaded bytes, right?
Could you name such players?
Old 24-07-2006, 06:56 PM   #7 (permalink)
prasad_den's Avatar
Definitely... It'll count in your download volume..
Here's the link to one cute little player of around 700KB size that has got many indian fm stations...!!!!
http://freehost14.websamba.com/nitinshinde/start.html
prasad_den is offline
Old 24-07-2006, 11:38 PM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
Thanks prasad but i figured it out myself on saving streams.
Old 25-07-2006, 12:52 AM   #9 (permalink)
String Phreak
mediator's Avatar
Well yea there are programs that satisfy u!. My bro uses these softwares everyday. Neways one of em is WMrecorder. Google u will find in plenty!!
mediator is offline
Old 25-07-2006, 02:01 AM   #10 (permalink)
Wise Old Crow
blueshift's Avatar
ok i have submitted a tutorial on recording online radio. check it out!
Listen & Record online radio in WMP/Winamp
thanks
Old 25-07-2006, 03:59 AM   #11 (permalink)
HELP AND SUPPORT
Is there a way i can listen 91FM and 98.3 FM in my comp...These radio stations are available in bangalore which i frquently listen in my radio
Meaning how can i listen AIR-All india radio online in my comp
Last edited by rakeshishere; 25-07-2006 at 05:54 AM. Reason: Automerged Doublepost
Old 28-07-2006, 06:03 PM   #12 (permalink)
Take this.....
Go it this link and download a very light application to play around 30 radio channels from all over the world.
http://rapidshare.de/files/27321437/...Radio.zip.html
Thanks
maindola is offline
Old 28-07-2006, 08:50 PM   #13 (permalink)
Wise Old Crow
blueshift's Avatar
I had download that file previously. And I had posted a tutorial too. Check it out:
Link
