Old 22-07-2006, 11:24 PM   #1 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
Unhappy A Simple Scheduling Query
Hullo guys...
I have this simple problem.
* I've this CDMA net conxn which is free from 10pm - 6am.
* I regularly download files through Flashget or Azureus BitTorrent client.
* So the thing is this ki though Flashget has got a scheduling option to hangup the conxn at 6am, but the same isn't there in Azureus.
* Is there any way that the torrent d/l stops and the conxn hangsup automatically at the desired time??
Do tell me guys...Its urgent. I've to wake up everyday at 6am and switch it off manually
Waiting for ur replies!!!
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 23-07-2006, 12:06 AM   #2 (permalink)
Brave_Hunt's Avatar
Default Re: A Simple Scheduling Query
If you are using XP try this.
1. Open Comand Prompt
2. Type Shutdown -s -f -t xxxx
3. Press Enter
Where -s is to confirm shutdown, -f will close all your programs before shuting your pc down, -t is timer that you can set to desired time and xxxx is time in second(s).
i.e. If you're downloading somthing and time is 10:30 PM you can set timer to close all your applications and shutdown pc at 05:50 AM by using this commad in "Command Prompt".
Shutdown -s -f -t 26400
Later you can wake up at your time and start your pc whenever you want.
One more importent thing. Once you initiate process you won't be able to close/stop it. To abort process type this in "Comand Prompt".
1. Shutdown -a
2. Enter
Where -a is to abort shutdown process.
Enjoy
And well said, E=MC˛ And there's a light!
Brave_Hunt is offline
Old 23-07-2006, 12:45 AM   #3 (permalink)
a_to_z123's Avatar
Thanks BraveHunt....
Will surely try this!!!
But is there any method to this through Scheduled Tasks???
Old 23-07-2006, 02:28 PM   #4 (permalink)
Brave_Hunt's Avatar
I'm afraid NO, You have to type command manualy everytime.
Old 23-07-2006, 03:23 PM   #5 (permalink)
String Phreak
mediator's Avatar
scheduled task is stupid!! Use "shutdown -s -t 120" in cmd ! where 120 is seconds before shutdown.
mediator is offline
Old 23-07-2006, 10:46 PM   #6 (permalink)
a_to_z123's Avatar
Chalo theek hai....
I'll have to do with this only.
Thx guys!!!
