Old 29-11-2004, 06:32 PM   #1 (permalink)
Default Please advise me for best PC configuration...
Hi, i want a best PC configuration for gaming purpose and 3d animation creation (3dMax, Maya, Flash). I can go upto 70-80K (INR) . Please help me to choose for -
CPU, MBD (with SATA, GIG LAN, RAID, OVER CLOCKING), RAM, HDD, DVD RW/ROM, Monitor-17"
Rest of the harware i can manage....Thanks Digit
:- few months back i read one article to build best pc....is that configuration will do enough for next 2-3 years ? Shall i wait for PCI Express technology and next OS release from MS ? longhorn ?
Thanks !
amitabh_kaushal is offline
Old 29-11-2004, 10:00 PM   #2 (permalink)
DUDDEEE ....
CHILL OUT ... i think u need to get ur facts a lil straight ...
and u need to think before dulging straight into buying a comp just cuz u have a high budget
take it slow
consider an AMD system ...
wait for a month .. ull get PCI-E in AMD machines as well
microsofts next OS is not scheduled for release before 2006
so windows XP is ur only option as of now ...
PS : longhorn is in ALPHA stage ... means its still INCOMPLETE ...
tho downloads are available ... but this is highly unstable
i wouldnt recommend runnin ur system on an incomplete OS
i aint helpin with ur config cuz frankly im tired
someone else will definitely come along with a good config for ur needs .
( KEEP AMD IN MIND !!! it rocks )
No Mercy, No Limits.
theraven is offline
Old 29-11-2004, 10:03 PM   #3 (permalink)
So you want a 'best' config ? No such animal exists. I or someone else could suggest a top-grade system far exceeding your budget, and then someone else can come along and nitpick it to death. Instead of choosing specific components, let's discuss some issues in general.
First, there is no question that at present AMD rules in the CPU segment.
Second, 17" monitors are mainstream now. A high-end machine would be better matched with a flat-screen 19" or larger monitor.
RAM : At least 1GB of DDR400, Crucial or Kingston. More RAM will give better performance, but it's a case of diminishing returns above about 1GB.
Graphics card : Ah, that could trigger another nVidia-ATI war. The fact is that at the top level, you won't notice much difference. I'm talking about real-life usage, not benchmarks.
At present, SATA has no real performance gain over a good PATA drive. Same with PCI-E vs AGP. One could say that since these are cutting-edge technologies, having them will future-proof your system. But even these standards will probably be upgraded in the not too distant future. Something like SATA-2 or PCI-E 2 will come along.
Hardware veterans call these 'bleeding edge' technologies - a disparaging term which implies that it's foolish to chase after every new-fangled technology as soon as they're released. Of course, if you have an unlimited budget and need every drop of benchmark point, that's a different matter. But most of us do not fall into that category.
Taking SATA in particular, it's been here for some time and SATA drives cost not much more than PATA drives, so there's no harm in having them. Just don't expect spectacular performance compared to PATA.
You gave no details about the magazine article you referred to, but no config can claim top position for six months, let alone 2-3 years. But if you choose wisely, it can still be a fairly good system even after 2 years.
pimpom is offline
Old 30-11-2004, 06:00 PM   #4 (permalink)
abracadabra's Avatar
Default Thiz Config Rockz
Sorry first of all if it DRILLS A HOLE IN U R POCKET.
Also take note that the market keep on rotating as there is no fixture for the hardware devices available these days. Almost everyday a new technology come up and changes the way we use computing. Its always better you do a little reviewing before you plan to buy any device
I can't be specific about the cost here. But you plan to use core applicatons like maya and mainly gaming, I would suggest the following:
PROCESSOR:
Intel Xeon Processor 2.8 Ghz/ 3.0 Ghz w/EMT 64t 800 Mhz FSB w/ 1 MB Cache (Could also go for AMD but I prefer Intel )
MOTHERBOARD:
Intel Original X2 Dual Xeon PCI Express Graphics Motherboard
VIDEO CARD:
NVIDIA Quadro FX 330 PCI Express 64MB DDR w/Digital Out (A perfect balance of all)
RAM:
1GB Dual Channel DDR2 Registered ECC SDRAM at 400MHz (Preferably from Corsair, Kingston. Could go upto 4 GB but very expensive)
SYSTEM DRIVE:
Extreme Performance - Serial ATA RAID 0 - 148GB (74GB x 2) Western Digital Raptor™ 10,000 RPM w/16MB Cache
OR
High Performance with Data Security - Serial ATA RAID 1 - 120GB (120GB x 2) Seagate Barracuda 7,200 RPM w/16MB Cache
OPTICAL DRIVE:
NEC ND-3500 16x Dual Layer DVD±R/W Recorder
SOUND CARD:
Creative Sound Blaster Audigy 2 ZS Platinum Pro High Definition 7.1 Surround with Dual Firewire (IEEE 1394)
MONITOR:
BenQ FP531 Black 15" LCD Monitor
OPERATING SYSTEM:
RED HAT (Cheaper than Windows OSes)
abracadabra is offline
Old 30-11-2004, 07:35 PM   #5 (permalink)
Sinnet's Avatar
ok m8
if u want something thats gonna make every guy enar u cringe cos of ur RIG here's the deal
Processor - AMD Athlon 64 3200+ Socket 939
MotherBoard - MSI K8N Neo2 Platinum (nForce3 Ultra Chipset)
RAM - Corsair CMX512-3200LLPRO Rs.10,800/-
DDR, XMS3200, 64Mx64, non-ECC, 184 DIMM, unbuffered, 2-3-2-6, 32Mx8 DRAMs, PRO Series w/LED, Low Latency ( You can get this from , NETWEB technologies mail: sales@netwebindia.com, netweb@vsnl.com
Mobile: 9891415996)
GFX Card - Ati Radeon 9800 XT or a Ati Radeon x800 AGP
HDD - Samsung SP1614C x2 (twin 160GB SATA w/8mb Buffer)
Optical Drives - LG GCE8525B (52x32x52 CD-RW)
and Pioneer DVR 108 (16x Dual Layer DVD +/- RW)
Sound Card - Creative Sound Blaster Audigy ZS2 Platinum ( If u dont need
u can stick to the onboard one as it's 7.1 too)
Monitor - 17" LG or Samsung FLAT CRT (You can never get a bright and
vibrant image on a LCD )
Speakers - Any Creative 5.1 channel as 7.1 Channel arent GOOD enuf yet
Keyboard + Mouse - Microsoft / Logitech Wireless Optical Combo
UPS - Any APC UPS
OS - Dont USE this as a Linux PC as it will spoil the FUN when it comes to
gaming
Get This and ur LOCKED and LOADED for One WIKID experience
EnJoY
sInNeT
Intel Core 2 Quad Q6600, 2GB Transcend DDR-II 667, Hitachi 320GB + 250GB SATA II, Sapphire ATI Radeon HD2600XT, ASUS P5B-Deluxe WiFi AP, Logitech G15, Philips 201B4......
Sinnet is offline
Old 01-12-2004, 02:19 PM   #6 (permalink)
Ethan_Hunt's Avatar
Well Check This Link Of Icecoolz This Will Help Ya Out With SOme Of your Options http://www.geek.com/htbc/glandre.htm .....but yeah MOst of it is Components not required though......plzz choose only ur requirements.....And yeah Might i Add The Sony GDM-F520 Trinitron 21" CRT monitor Is a Bit too high So U can Strip That Off and Go In for A Samsung 19" Crt For that matter And well i dont suppose all these mentioned parts are a easy Availability option in Mumbai atleast....but u can get a pretty decent Idea Of ur config And Ur Quest For A High Performance Config....SO Happy Buying Mate....
Ethan_Hunt is offline
Old 01-12-2004, 07:52 PM   #7 (permalink)
hello.
Look, first firmly decide what you want. A best gaming machine or best 3d animation machine.
If you are mainly a gamer and casual 3d animator then you must go for Athlon 64 system. Athlon 64 is best platform for gaming.
I will just tell you an real life example.
I had P4 2.6C oced to 3.25Ghz. RAM in 1:1 so no bottleneck.
I have GF 6800GT 256MB GDDR3 graphic card.
My P4 was pulling our 108 FPS in CSS stress test.
I just upgraded to Athlon 64 3200+ S939.
Everything else is same. Same RAM chips same everything.
Now I am pulling out 128FPS in same CSS stress test.
Thats enough idea how strong Athlon 64 are in gaming.
On the other hand if you are casual gamer and your primary work is Animation, Maya, 3dsmax then you must go with high end P4 system. Pure extra clock speeds of P4 help it a lot in these applications.
Here is a config i suggest for gamer.
ASUS A8V deluxe WIFI edition mobo.( 4XSATA Raid, 4X IDE raid support)
1GB PC 3200 DDR RAM.
2x120GB WD HDD raid 0 config.
450 watt good quality PSU.
1X DVDRW
1X DVD ROM
Geforce 6800Gt graphic card.
19" CRT Monitor.
SBLive Audigy2 sound card.
Creative 5.1 speakers
THis will fit in 80K budget
If you are casual gamer and more of animator. then change processor to P4 LGA 775 3.4 Ghz and ASUS 925X chipset mobo.
Rest all can be kept same.
This will not fit into 80K budget as 6800GT PCI express card is much more expensive than AGP version. Costs 36K against 27.5K for AGP version.
So if you want to limit it to 80K you will have to sacrifise on graphic card and settle for 6600GT or skip audigy2 and 5.1 and go for onboard audio + 4.1 speakers.
Choice is yours.
funkymonkey is offline
Old 01-12-2004, 11:43 PM   #8 (permalink)
Blah Blah Blah Blah.
Wait for atleast 45 days and post it again
rakesh_1024 is offline
Old 02-12-2004, 12:08 AM   #9 (permalink)
ha. This way he will always keep waiting.
First people said wait wait new A64 is comming.
Then said oh wait new S929 is comming then oh wait PCI express is comming. Then oh wait, SLI is comming. Now wait for 2 more months PCI-Express 150( new PCI express X16 standard which can provide 150 watts to your card rather than 75 which current PCI express can) will come.
This will never end.
AGP is not dying anytime soon and performance of AGP cards are on par with PCI express and even better in some cases.
Hell if you wait for another month there will probably be 1066FSB LGA 775 P4 out.
And if you wait 6-8 months there will be dual core processors.
This is not gona end ever.......
Get the stuff you want right when you want. There will always be something new in a month or two.
Old 02-12-2004, 01:42 AM   #10 (permalink)
Itz about the right time to buy.
Whenever a guy buys a PC or a component, he shouldn't fel that he should hav waited a month or so.
We are not talkin about small changes in the PC industry.
Itz about newer standards being implemented at cheaper prices
And all the companies would be performing a bull fight since the new year.
And most of them normally wait for Jan for implementation and offer them as New Year Gifts to Consumers.
I hav a PC too and bought many addons to it. But I bought them only when the time waz right.
Only If it waz urgent, I used to buy them without botherin about the so called "Right" time
Old 02-12-2004, 11:59 AM   #11 (permalink)
well look at it this way. There's 3 major changes in the horizon. 64bit computing, PCI-E and DDR2 and also do not discount the dual processors that Intel is working on and also the SLI's from nvidia. With this amount of changes I would have to wait for a year at the least before anything stable is out there. 45 days aint gonna be enuff. Right the first 3 are the biggest changes in the PC industry. And the 64 bit computing will not take off till the 64 bit OS from microsoft becomes commercially available. So waiting is not the answer. Like funkymonkey suggeste fix onw hat you need and go for it.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 03-12-2004, 06:45 PM   #12 (permalink)
i suggest you to post this in the topic'need help on pc configuration'.it will reduce clutter.
RJ THE GREAT
ranjodh is offline
Old 06-12-2004, 06:35 PM   #13 (permalink)
Default Thanks to everyone...
Thanks a lot Friends! Your valuable suggestion helped me a lot and i can manage to buy a good configuration in my budget.
