Old 22-07-2006, 11:06 AM   #1 (permalink)
TechTin.com
ravi_9793's Avatar
Default how to add two hard disk
hello frnds..
my computer config is as follow...intel original 915,p4 2.8,80gb sata hard disk,512 ram.
Now i want to add another 160 gb hard disk along wid my old hard disk.
How can i do this,....and also i want to make my old hard disk master.
plz explain in detail.
ravi_9793 is offline
Old 22-07-2006, 11:45 AM   #2 (permalink)
Default Re: how to add two hard disk
You havent mentioned if the new hdd is sata or pata...
For pata, just attach the new hdd as primary master IDE, then in BIOS, set up boot device to the sata hdd...
Arun
sakumar79 is offline
Old 22-07-2006, 11:46 AM   #3 (permalink)
Venom's Avatar
For sata you can use RAID 0.
Venom is offline
Old 23-07-2006, 06:53 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
new hard dis is also sata
hey ...frnds..
i have solved my problem.it was very easy....
thanx for ur kind suggestion.
