Old 22-07-2006, 08:39 AM   #1 (permalink)
Post Zip repair?
hi,
I am using Win XP SP2, Recently i deleted a 101MB zip file, Thou i recovered it using S/W PC Inspector File recovery, But nw the zip file opens and all the files in it are displayed but the files are neither exctracted nor opened.
An error comes that "unknown compression method" used for WinRAR and windows Extractr.
Can anybody help.
navisangha is offline
Old 22-07-2006, 10:48 AM   #2 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default Re: Zip repair?
dont get scared but u might not b able to get the files bek......mostly bcos the files crc code will b possibly destroyed wen u deleted the folder...all i can say i try some other recovery software....
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 22-07-2006, 11:46 AM   #3 (permalink)
Also, try the repair feature of WinRAR.
Arun
sakumar79 is offline
Old 22-07-2006, 11:52 AM   #4 (permalink)
Google Bot
Pathik's Avatar
@sakumar repair doesnt work for me netime
Pathik is offline
Old 22-07-2006, 04:52 PM   #5 (permalink)
The Researcher
Actually your file has not been recovered properly. If you have not already defragmented your hard drive, I may suggest you use Recover4all pro . It does a nice work and and very reliable. It has saved me from many nasty situations.
Ramakrishnan is offline
