Old 29-11-2004, 06:00 PM   #1 (permalink)
Default TV Tuner for a Laptop
Hi All,
Can I watch TV on my Laptop....i mean can I connect a TV tuner card (obviously external) ....to my Laptop? If yes, then which one? Would b greatful if you can give me full specs.
Thanks
tiwariG is offline
Old 29-11-2004, 10:03 PM   #2 (permalink)
yup u can
look for any external tuner yaar
all external tuners ...( atleast the ones i know ) connect via the USB port
so all u need is a free usb port on ur lappy
check out pinnacle .. they have a decent solution !
[edit] u can look up specs and prices by a quick search on bazee
here ya go
http://www.baazee.com/static/Compute...ner_Cards.html
No Mercy, No Limits.
theraven is offline
Old 30-11-2004, 01:23 AM   #3 (permalink)
I have seen some PCMCIA card based tuners for around rs5000...
They should work better than the USB2 external tuners.
AlienTech is offline
Old 30-11-2004, 12:12 PM   #4 (permalink)
King of my own Castle
freshseasons's Avatar
A Pixelview USB card i use with my laptop serves me fine...its not too costly as a PCMCIA based tv tuner card..Other thing tough remember,...you need atleast 1 Ghz Processor a 128 Mb ram and usb 2 To get decent frame rates on external USB Tv tuner card.
Hope this helps you
freshseasons is offline
Old 30-11-2004, 11:20 PM   #5 (permalink)
Can you give me exact specs for that usb card please, cost and where can I aquire one for my laptop?
mohsin_parwez is offline
Old 17-12-2004, 10:23 PM   #6 (permalink)
Its about rs5-6000
PixelView Play TV Pro TV Tuner Box with Remote
PixelView PlayTV USB pro provides the capability to watch TV, capture motion video images, snapshot still images, receive and display life videos by connecting to V8, Camera, Camcorder, VCR, VCD and DVD player. Also you can get Teletext data when watcheing TV.
It's designed for Notebook, Desktop PC with USB port and it supports hot plug & play and easy to use without opening your PC. PlayTV USB pro combines TV with your PC to save space and you will get more multimedia functions than a TV set.
Features
NT1004 USB decoder chip + SAA7113 video decoder chip
Supports hot plug & play with USB portFully PCI Rev 2.1 compliant and zero wait state PCI burst write.
Supports NTSC/PAL/SECAM TV system
125-channel cable TV reception
Full TV frequency range for CATV/VHF/UHF
Supports Video/S-Video input
Capture rate up to 30 frames per sec at CIF format (352 x 288 pixels).
Supports resizable video window size up to 640 x 480 pixels at VGA mode
Supports hardware & software snapshot
Video Conference ready
Video capture rate maximum 30 frames/ second. Video Conference ready
Supports decoded YUV 4:2:2 image inputs
Old 22-12-2004, 06:45 PM   #7 (permalink)
why not buy a frontech external one 4 bout 2k
B Yourself
cool.crook is offline
Old 22-12-2004, 07:04 PM   #8 (permalink)
Really ! Does it have USB Connection to connect to LAPTOP.
Old 22-12-2004, 07:42 PM   #9 (permalink)
The rs2000 external ones only let you connect a VGA type monitor upto it.
Both the USB and PCMCIA ones are over rs5000.
