Old 20-07-2006, 11:43 PM   #1 (permalink)
pop143's Avatar
Smile Run my own webserver...!
i know its tough and not faesible all time..! but still..
how can i run a web server of my own..!! on my P 4. 1.8 ghz,40gb,256mb ram like they do with xeon, titanium on net ..??? for me alone..! less traffic.!
i want all the features php,sql etc..to be installed on my own systemm.??
wot softy 2 download..??
plz give me the basics of running a web server.!
i lost interest on other 3rd party servers..if u use any free hosting cpanel and say its best..and easy tell me plz..!! ie:free it shud be..also !
have 2 host a vbulletin board there..!
-thanks.
pop143 is offline
Old 20-07-2006, 11:51 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: Run my own webserver...!
Tutorial Here vbulletin!!! ....... use phpbb
http://beingmanan.com
iMav is offline
Old 21-07-2006, 09:43 AM   #3 (permalink)
String Phreak
mediator's Avatar
1. Install ISS from ur XP Pro Cd.
Run services ISS and www service from "services.msc"
2. Add aliases and other directories.
Suppose u alias C:\pop143 as popo...then u run it as http://localhost/popo.
3. Install php....run a test file from popo directory a "http://localhost/popo/test.php
4. SImilarly install mysql....and see its configuration if u face difficulty in integration with ISS.
For any term u dont understand like aliasing of directories for ISS ....google it!!
mediator is offline
Old 21-07-2006, 10:33 AM   #4 (permalink)
tuxfan's Avatar
Hosting your own site! with all possible scripting supports
Since there is an existing thread on the topic, I have closed this one. PM me (or any other Admin/Mod) if you need it re-opened.
tuxfan is offline
